Introduction: Replacing Your RV Motorhome Camper Fresh Water Pump Install Save Your Money and DIY
About: Do It Yourself How To's Save Money or make custom creations Autos, RVs, Boats, Wood working, Welding, Maintenance, Home Repairs, Camping and More
When you winterize you also inspect for issues
Our inspection found a water pump wear issue here we replace it before failure!
Using these links to select your Pump and Supplies helps support the projects!
“As an Amazon Associate I earn from qualifying purchases.”
Water Pump 4008-101-E65 42-Series 12V 3.0GPM 55PSI Diaphragm Pump Compatible with RVs, Ships, Yachts, and Boats - Self-Priming 9.8 Feet https://amzn.to/3zMxee9
KAIWEETS Wire Stripper 10-22 AWG Wire Splicer Cable Stripper Multipurpose Wire Stripping Tool Electrical Wire Pliers with Screw Cutter
https://amzn.to/3zfPBrE
TICONN 200PCS Heat Shrink Butt Connectors Kit, Insulated Waterproof Electrical Marine Automotive Wire Crimp Terminals, Butt Splice (3 Colors / 3 Sizes)
https://amzn.to/3tkjMKV
Step 1: Remove Older Pump
The video shows all the details
Step 2: Prep Work for the New Pump
Clean area and collect the supplies and tools to install
Step 3: Install the Pump
Step 4: Test Pump
Save the old Pump as a spare "An old pump is better than NO PUMP"
Step 5: Thank You for the Support
