Introduction: Rescue Robot
I made a robot that carriers items or people that need to be delivered somewhere. I made it so that if something or someone needs to be delivered somewhere safe in a short amount of time this robot can take you.
I used: a micro bit, a servo motor, 3 alligator clip wire ( red, black, and white ) , three jumper wires ( same color) and Legos, wire tape and clear tape.
Step 1:
To start you need to use Legos to make the robot. Use Legos of your choose to make the robot look as close as it possibly to mine.
Step 2:
Second you need to go to Microsoft makecode to write the code. Code is in the picture. To get servos, click add extensions and the servos will pop up. If you don't see them search it up and it should show up. The color when you add it should be teal.
Step 3:
Third attach all the wires. I'll attach a video showing how to attach them.
Step 4:
Use the servo motor and attach it to the arm of the robot. Hold the servo motor and press the button of the Microbit. The arm should move.
Step 5:
Have fun building the robot and if you struggle try to figure out other ways to figure out what your struggling with.
