Resetting Forgotten Windows 7 Password
160,327
67
23
Introduction: Resetting Forgotten Windows 7 Password
Have you forgotten the password to your Windows 7 machine and don't have a Windows Recovery Disk?
In this instructable I'll teach you how to reset the password to your account in roughly 20 minutes.
It is intended for educational purposes only. I will not be held responsible for any misuse of this instructable. This instructable may or may not work on certain computers due to the start-up repair mode being locked by some administrators.
Step 1: Equipment Needed
Laptop/Desktop running Windows 7
Monitor
Mouse
Keyboard
Step 2: Entering Windows Error Recovery
Tap F8 when the Windows Splash screen begins to load. Upon entering the Advanced Boot Options, you may or may not see the "Launch Startup Repair" option, if possible click on it, if not, press control-alt-delete, and repeat the previous steps.
Step 3: Start-Up Repair
Wait until the Start-up Repair has finished checking your computer for problems, then click on the problem details, and scroll down and click the link: X:\windows\system32\en-US/erofllps.txt.
Step 4: Accessing File System Part 1
Click on file, open, then click on the computer image. After doing this, click on your main hard disk drive, it varies for different computers, in my case I click on drive "C:". If you click on the wrong drive, click on the computer icon again and try the next drive.
Step 5: File System (Continued)
Click on Windows, then change the types of files to 'All Files', after doing this click on 'system32'.
Step 6: Copying and Renaming Files
Make a copy of the 'cmd' (Command Prompt) and rename the copy 'sethc' (this will modify the system's accessibility options) and rename the other existing 'sethc' file 'sethc1'. This step essentially reassigns the accessibility of the command prompt. Now exit the window and when prompted to continue the system restore or cancel, click cancel.
Step 7: Resetting Password
Start your computer up normally. When prompted to enter your password at the login screen, tap shift key about five times, this will cause the command prompt to appear. Type in net user (your username) and your new password.
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Metal Contest
      Metal Contest
    • Crayons Challenge
      Crayons Challenge
    23 Comments
    sudeshrana30
    sudeshrana30
    1 year ago
    It showing like this..what to do
    idkyouth
    idkyouth
    Tip 1 year ago
    I got an 'access denied' error when running the net user command. Fortunately, I managed to reset my forgotten password with PassMoz LabWin. It is fast and no data loss
    sjacksonmail
    sjacksonmail
    Question 2 years ago
    I am running Win7 Pro on one computer and Win7 Home on another: in both cases, the files setch or utilman do not appear in the System32 folder. What to do?
    youjustdontgetitdoya
    This worked for me! Thank you so much. I can't believe this is even possible. Very hacky. Sending lots of love.
    Cavals
    Cavals
    3 years ago
    Just make a few changes with your trick and we can get it to work with Windows 10 and Windows Server 2019 - https://youtu.be/h2OEtnL6jNI
    acmarston
    acmarston
    Reply 3 years ago
    Thanks.
    nnekings
    nnekings
    3 years ago
    @Tesuizy's suggestion is much more easier! The password is reset by PassMoz LabWin almost instantly!
    Tesuizy
    Tesuizy
    Tip 4 years ago
    It is a great tutorial. However, for most of people, this method is so hard especially those who have less computer skills. Actually, it only takes a few minutes to remove the password with PassMoz LabWin. I just did it on my Windows 10 laptop.
    nnekings
    nnekings
    Reply 3 years ago
    Password was removed instantly and no file being deleted. much easier than command prompt lol
    bravofirst17
    bravofirst17
    Question 3 years ago
    If I have an account administrator account named user @ cmd prompt >user?
    ClaireG48
    ClaireG48
    Question 4 years ago on Step 6
    I push copy but nothing comes out. What do I do?
    wristcheek
    wristcheek
    4 years ago
    Just boot your PC from Windows 10 installation disc, open up the Command Prompt and replace sethc.exe with cmd. Reboot to the login screen and you can access an elevated Command Prompt, and reset your password using the net user command.
    You can also follow this youtube video to reset your password.
    https://www.youtube.com/watch?v=Nd5emNUVDAM
    intwrisit
    intwrisit
    Reply 4 years ago
    I bought the iseepassword Pro version and downloaded the software to a 2GB USB drive, it helped me reset my login password on my windows 10! Thanks!!
    wristcheek
    wristcheek
    Reply 4 years ago
    Thanks, i used iseepassword to rest my local admin password on my win 10, 64 bit.
    Reynolds5
    Reynolds5
    4 years ago
    No matter what I do, I still couldn't access Startup Repair with Windows 10. In the end I used a bootable media to obtain access to my computer account:
    SevenT3
    SevenT3
    5 years ago
    thanks for sharing, I am very inspired by the existence of this article. I have a blog topic that is almost the same. I hope we can share and be a friend who can always give positive feedback. but my blog using indonesian language.
    cara Reset password windows 10 8 7 tanpa CD
    liviazero
    liviazero
    5 years ago
    Thanks for the sharing,but it is little difficult for me to understand maybe I am not easy with this kind of issues.I usually use password tool http://www.passwordmanagers.net/products/Windows-Password-Recovery-Software-1.html Windows Password Recovery Software
    to deal with them, it works very well and easy to operate, free download now
    iSpaol8
    iSpaol8
    5 years ago
    If you forgot Windows local administrator password, this password recovery tool can help you recover it in a fast and effective manner , supporting for all major Windows systems. This following tutorial explains how to use Windows Password Recovery Professional to remove/recover your Windows local user password.
    User guide:http://www.imoresoft.com/windows-password-recovery.html
    gordie3131
    gordie3131
    6 years ago
    If you forget the login password for your Windows, I recommend you to try iSeePassword Windows Password recovery tool, with it, you can create a reset disk with your USB and then you can easily unlock your password.
    I personally used this method and it worked perfectly!
    peterfan
    peterfan
    7 years ago on Introduction
    use renee passnow to reset the windows password:
    http://couponcode0.com/renee-passnow-basic-version.html
