Introduction: Resin Knobs and Rings
Grab everything from the hardware store to make resin rings and knobs for your dresser!
Step 1: Watch the Video Tutorial Here!
Step 2: You'll Need
Screws and nuts
Buttons, glitter, beads and Confetti
Craft knife
Cardboard
Plastic cups
Silicone mold
Step 3: Prepare the Cardboard
Cut your cardboard in squares
Cut out section of the cardboard so you can slip on the hose clamp just under the screw
*Make sure it's secure
Cut small holes in the center of the cardboard squares for the screws
Step 4: Prepare the Glaze Coat Epoxy/Resin
Mix equal parts of the Glaze Coat for 5 minutes
Pour 1/4" in each mold
Step 5: Fill, Cure and Remove
Fill with your glitter, buttons and confetti
Pour the Glaze Coat almost to the top of the mold, but not quite
If you notice bubbles, blow on top of the filled hearts until they pop
Carefully position the head of the screw inside a Glaze Coat filled heart
Position the screw part of the hose clamp inside the heart
Make sure the cardboard does not touch the Glaze Coat
Let dry overnight OUTSIDE under a cardboard box or in part of the house you're not occupying
Step 6: Remove and You're Done!
Carefully remove the cardboard and sand the edges at the base if you need to.
