Introduction: Resistor Figure
Do you have any unused / broken electronic components? Do you have any unused creativity?
If that's the case, making a resistor figure will solve your problem.
Step 1: What You Need.
You need the following:
* Soldering iron.
* Solder.
* Small plier.
* Cutting plier.
* Unused / leftover electronic components.
* Soldering iron.
* Solder.
* Small plier.
* Cutting plier.
Step 2: The Basic Joint
Building resistor figures is easy, once you know the basic joint. (I prefer using a joint instead of soldering straight leads together, because they are more firm).
* Using a small plier, bend the leads to small circle.
* Fill the circle with solder.
* Connect the components by melting them together.
Now, continue to create your animal or figure.
Step 3: Need Inspiration?
Here is some inspiration..
