Introduction: Restoring a 1965 Rockwell Compactool Jointer
Before my Dad passed away he had tools and other items that he wanted to make sure I received as he knew my passion for Woodworking and older collectibles. He stated that the jointer worked and it was given to him by a very good friend of his.
When I got it home I went on line to understand when they were made and what was behind the Rockwell Compactools. I went on vintagemachinery.org to obtain a manual as I knew I was going to take the tool apart to restore it.
http://vintagemachinery.org/mfgIndex/detail.aspx?id=1141&tab=3&sort=2&th=false&fl
Step 1: Tools and Supplies Needed to Restore the Jointer.
1. Mothers Aluminum Polish
https://www.amazon.com
2. Buffing Wheel
3. Soft Cloth ( sock or cotton t-shirt )
4. Red Paint ( you can use any color )
Lowes rust-oleum
5. 4 feet of 14 gage 3 conductor wire
Lowes
6. Elbow grease ... lot of it.
Step 2: Re-wiring the Jointer
Figures 4 - 5 show the new wiring. I had to remove the motor and solder the new wire in then attach to the switch.
Once re-wired I turned it on and it ran like new, the motor sounded strong and the Jointer had little to no vibration.
Step 3: This Was the Condition When I Received the Jointer
As the surfaces that I wanted to restore was Aluminum I new I wanted to use Mothers Mag and Alum. Polish.
I took the fence off and noticed some light scratches on it and the table so I did the following;
a. I used 400 grit wet and dry sandpaper to remove the scratches
b. I then moved to 600 grit wet and dry sandpaper to start to polish the metal
c. I then used Mothers on a buffing wheel to give it a deep polish
d. In areas that I could not get close enough with the buffing wheel I polished by hand
Step 4: Table and Fence Polished. I Painted the Blade Cover and a Few Knobs and Replaced the Wood Base
Thanks Dad..
Love Bruce
