Introduction: Retractable Helping Hands (My Mini Soldering Helper!)
Most of us "electronics people" know that 2 hands usually isn't enough while working with electronics, It isn't surprising when you mess up because you have to hold a Circuit Board, Components, Soldering Iron, Solder, Wire Cutters, and a million other tools, With only two hands!
And for that exact purpose, The Helping Hands tool was invented. The only problem is that they can be pretty expensive.
That's why I decided to make a Retractable Helping Hands Tool using parts of an old IKEA reading lamp, Which means it was FREE!
Time to start making!
Step 1: What You'll Need:
Materials:
A Flexible (IKEA) Lamp
Teeny Tiny C-Clamp- Buy a 2" C-Clamp here for $3, Or make your own here (My grandpa had these and gave me them, So I got them for free)
Epoxy Putty (Vinyl Gloves and a Utility Knife are recommended to use with Epoxy Putty)
Note: You can always use a small, cheap spring clamp if you want. It might look like a small version of this
Tools:
Wire Cutters
Needle-Nose Pliers
Vinyl Gloves
Small Hammer (optional)
Flat Screwdriver (optional)
Step 2: Removing the Lamp Parts
Not all lamps are the same, But most lamps should be easy to take apart:
After removing the light-bulb, Cut the cord with wire cutters, And un-screw the reflector-protector-cover-thingy!
You should be left with the flexible arm, And the spring clamp (Picture #1)
Step 3: Clamp Holder
This isn't pictured, But I took the "reflector-protector-cover-thingy" apart and inside of it, I found another piece of metal that I thought could be useful (Picture #3). This part reminds me of a 110V plug, But DO NOT plug it in to an outlet! I said it reminds me of one!
I screwed it in to the flexible arm, And bent the prongs around the clamp. (Picture #1)
This can easily be done with Needle-Nose Pliers, A hammer might also come in handy
Step 4: Epoxy Putty
I decided to use Epoxy Putty to help strengthen the connection between the clamp and the flexible arm.
I kneaded the Epoxy Putty until I got the 2 chemicals mixed properly, And applied it on to the both parts. I made sure that the Epoxy covered everything
You might also be able to use a welder for this, But I don't have one, So I don't know...
Step 5: More Pictures/More Uses
Here are a couple more uses for my Retractable Helping Hands!
I hope you enjoyed my Instructable! If you wan't to see more projects like this, Don't forget to visit my Instructables page and subscribe for more future projects!
Help support more "yonatan24" projects by clicking that big orange "VOTE" button in the top right corner of your screen! THANK YOU!
If you build a something that is similar to what I built, Please post a picture in the comments to show everyone!
