Retro TV Cat Bed
Intro: Retro TV Cat Bed
As you can see based on my instructables, my girlfriend loves cat beds. This is my latest creation with an old tv I found.
STEP 1: Find Tv
First you need to find an old tv. I found mine for $30 on Kijiji. You might be able to find one on Craigslist or eBay, or an antique shop.
STEP 2: Dissassemble
IMPORTANT: DISCHARGE TV FIRST.
Then take apart entire tv with a screwdriver and cut all the wiring with scissors. You might need a pair of needle nose pliers to pull some clips off.
STEP 3: Clean and Paint
Once you have the tv all apart, throw away everything you don't need and keep everything else (dials, screws, antenna for looks). If you want to paint the tv you should clean the plastic housing with soap and water. Once it's all cleaned up, spray the tv outside with plastic spray paint. I painted the tv all red first. When the red dried I tape over all the red I wanted to keep and spray painted the part that surrounds the tube black.
STEP 4: Assemble
After you sprayed a few coats of paint and let it dry you can put the tv and dials back together. At this point I spray painted the inside blue being very careful not to get any on the red or black. Make sure there are no sharp parts that your cat could hurt itself on. I used a dremel and sanded down a few sharp points sticking out of the dials on the inside. Fold a little blanket inside and you're finished! Hope you enjoyed it. Leave comments and ideas for more projects!
5 Comments
MerlI1 3 years ago
davee930 3 years ago
rachl009 10 years ago
Kayak Kid 10 years ago
poofrabbit 10 years ago
