Introduction: Reupholster a Chair Cushion
This is a beginner type re-upholstery instructable for the chairs that only have a single cushion that you sit on. I do not know how to use a sewing machine. All of this can be done with hand tools and each chair cushion can be done within an hour... from start to finish.
Scissors
Hammer
Staple Remover
Pair of Pliers (to help with the tough nails/staples)
Spray glue 77 or similar fabric adhesive.
Some Dacron type foam
1/2 inch foam (optional)
Upholstery Staples (about 1/2 inch or so)
Staple gun. (I have a pneumatic one, but a hand held one can be used)
The new Fabric
Dust Cover (for the underside of the chair)
Step 1: Remove the Old Fabric
You start with unscrewing the seat from the chair. In general, this is 4 screws on each corner of the chair that need to be removed. You can do this by flipping the chair upside down and you should b able to see the screws right away.
Then comes the tedious (and most time consuming part of this job) of removing the staples.
Be careful of those staples that break off rather than come fully out. They will be sharp. If I cannot get them out with my pliers, then I hammer them flat so they do not catch on the new fabric that you will put on (or your fingers).
Step 2: Add Foam and Padding
If the original cushion has little to no cushion I will add a 1/2 inch foam material.
I make the 1/2 inch foam the same size as the existing chair cushion. See photo, where I cut out the two back corners of the foam (as that is where the back comes up).
I add the foam by first applying a layer of adhesive on both the foam and the existing seat, then letting it sit for a minute or two to get a little tacky (read the instructions, as each adhesive could be a little different).
Then I add a dacron filter type material to add a little more cushion and to help with smoothing the final lines when I put the new fabric on.
I attach this in the same way, with the adhesive. And once tacky, I stick them together and fold the sides over the bottom. On this particular chair I had to cut out the same section as I did with the foam (due to the back of the chair) and also cut the front corners diagonal (so that they do not overlap when stapling it all together).
I do not staple anything to the top of the chair. This could possibly be uncomfortable in the future, when sitting on it.
Step 3: Add the New Fabric
At this point I have the fabric ready to go. It is also big enough for me to staple to the underside of the chair.
You have to be particularly cautious around the corners as they tend to bunch up and have a lot of wrinkles. I resolve this by pulling all the fabric in the corners tight and then stapling it while I am holding it.
Once completed with all four sides of stapling, then I cut off all the extra fabric that will only bunch up and look a bit unsightly.
Step 4: Bottom Side of the Chair Cushion
The next step is to use a "dust cover" to cover the bottom of the chair. This is a thin black material that prevents any droppings from the chair (such as foam bits) to fall to the floor.
I just placed it over all the unsightly folds and staples and just stapled it on
This fabric is just a cosmetic cover really.
Step 5: Completion
This is what the reupholstered cushion looks like.
Then I attached it to the chair and it looks brand new.
