Introduction: Reupholster a Couch With Old Jeans
I enjoy using old jeans to make new things. Denim is an extremely sturdy fabric. I've made throw pillows and purses out of old jeans but this was a very complicated project.
You will need the following items:
A couple dozen (at least) old pairs of jeans
Several yards of medium weight denim
Staple gun (I used an electric one and it made all the difference)
Upholstery tacks
Hammer
Pliers
Flat head screwdriver
Sewing machine
Dark Blue thread
measuring tape
Step 1: Acquire an Old Couch
Before you remove the old upholstery, measure each section and make a list of how many you'll need. For example, the front of the back section is 1, the arm rests are 2, the side pieces are 2, the back of couch is 1 and the cushions are 3.
Remove the cushions. Set aside for later.
Carefully remove the old upholstery and use it to make a pattern for the denim patchwork. Or you can just measure each piece at the widest point.
Removing the old upholstery tacks and staples was very time consuming. Give yourself enough time to do this. Just when you think you have all the staples out, look again. This is where the screwdriver, hammer and pliers comes in to work.
Step 2: Front of the Back Section
To cover the front of the back section, Measure horizontally and vertically, adding several inches on each side for the stapling. Cut out the old jeans into 7" squares. You will need at least a couple of weeks to do this step. When you think you have enough squares to get started, Sew them into a row using 1/2" seam allowances. Press the seam allowances open and sew a 1" wide x 7" long piece of fabric (it doesn't matter what color it is because it will be on the underside.) Place it under the seam and top stitch. This will reinforce each seam. Cut 3" wide strips from the medium weight denim and sew the rows together to construct a piece large enough to cover the front of the back section. Begin by stapling to the back of couch, then pull the fabric down tight and staple to the underside of the couch frame. On the sides of the back section, you may need to clip the fabric at the curves and at the point where the back meets the arm rests. Pull the fabric tight and staple to the back of couch.
Step 3: Arm Rests
Measure the Arm rests at the widest points. sew the squares together, reinforcing the seams as in step 2. Depending on how your couch (or chair) is made, you may need to Sew the arm rests together before attaching to the couch. I learned how to do basic upholstery by watching several YouTube videos. The widest point of the arm rests of my couch was at the bottom so I ended up trimming off quite a bit of denim at the top front section of the arm rests.
Step 4: Sides of Couch
To cover the sides of couch I sewed 2 rows of squares and started stapling at the top edge, turning the denim fabric under 1" and overlapping the fabric from the top of the arm rests. Stretch and staple to the underside of the couch.
Step 5: Front of the Bottom Section
I made one long strip of squares and then sewed a row of medium weight denim to the top and bottom of this. It's very important to reinforce the seams because even though the denim is strong, you don't want it coming apart at the seams after all of your work.
Step 6: Under the Cushions
Since the fabric under the cushions won't be visible, I used the medium weight denim. I had an old blanket that I cut to fit and placed it under the fabric. Staple it to the frame on the backside of the front section. Pull fabric tightly and staple it to the back of the couch.
Step 7: Back of Couch
I covered the back of the couch with the medium weight denim. The electric staple gun came in really handy here. Start at center top. Turn under top edge of fabric 1" work your way out to the sides. Next staple the sides of the back starting at the top and working your way down toward the bottom. Lastly, staple the bottom edge to the underside of the bottom of couch.
Step 8: Details
The smaller pieces on the front of the arm rests and the top of the sides are for covering the places where the ends of the fabric are. Cut some denim about 2" larger than each piece and tack the denim around it. You can attach these with new upholstery tacks. I found it helpful to hold the upholstery tacks with needle nose pliers while hammering, that way you don't hit your thumbs.
Step 9: Cushions
The top of the cushion is the only part that I made from the patchwork, the sides and bottom are constructed from the medium weight denim. You may choose to make the underside of each cushion patchwork so you could flip them over. You could also add a zipper on the back of each cushion for removal and washing but I couldn't find zippers long enough. Don't forget to add 1/2" for seam allowances. Sew 3 sides and place the foam cushion inside cover and then hand stitch closed.
Step 10: Finished Couch
This was a huge project and at times I wondered if I was in over my head but I just focused on one section at a time and am pleased with the way it turned out.
