Introduction: Reverse Engineering Air Conditioner IR Remote Control Protocol
Hi, this is my first instructable, hope you like it.
To get into electronics I chose a home automation project: a system allowing me to control and program both air conditioner units in my flat. In this instructable I show how I got to understand the IR protocol.
Material:
- Panasonic inverter air conditioner remote control
- Raspberry Pi with raspbian and lirc installed
- 38kHz Infrared (IR) Receiver Module (for instance RadioShack Catalog #: 276-640)
- breadboard
The raspberry Pi is useful in my setup to analyse the incoming IR signals, but also to host other components on the global project. Any other computer equipped with an IR receiver could do. An Arduino could also output the needed information using the IRremote library (https://github.com/shirriff/Arduino-IRremote). This library will be used to control the air conditioners in the end.
The method used here could work with other remote protocols (with adaptations).
Please excuse the screen caps that don't show exactly the same output format: this part of the project was done during last summer and I used files generated by multiple versions of the codes I wrote.
Step 1: The Remote to Study
The remote shows multiple options to transmit:
- The target temperature to achieve
- The "mode" ("cool","heat","dry", "auto")
- The air flow swing (5 possible positions, and one automatic mode)
- The fan speed
- A powerful or quiet option (which impacts the fan speed (and more?))
- 2 timers: one to turn off the unit after a certain amount of time, one to bring it back on
One thing to know is that usual remotes controls, for TV, HI-FI, ... send a signal for each key pressed (often in loops while the key is pressed). An air conditioning remote often displays information about the parameters selected. But of course parameters can be changed on the remote while the unit is out of reach, which could lead to synchronization problems between the display and the unit in some cases if it worked like the TV remotes. This implies that when such a remote sends a signal, it sends the whole parameters set. What we'll do is then study what signals are sent to try and understand which part of the signal is for which parameter.
Step 2: Gathering Data
Off we go.
Note1: command recording is a repetitive and slightly boring process, but necessary.
Note2: I don't own an oscilloscope so the only way for my to plot the recorded values is to use a plotting program (gnuplot) on raw data. This can useful to have a visual idea of what happens, but it requires some adaptation in raw data and is in my opinion not necessary at all. For that reason I have not included any graph.
I used the instructions from this page: http://alexba.in/blog/2013/01/06/setting-up-lirc-... to plug the receiver on the Pi and prepare lirc.
I then recorded commands with the -raw option and redirected output to a file. The goal is to have a record of each value for ON and OFF of course, but also for each mode (AUTO, COOL, HEAT, DRY), for each swing and fan value, and, say, for min and max temperature (16 to 30°C in my case). The important part here is to make a reference record and to make a recording for each change of option, making only one option change every single time. Once a record is done, press CTRL+C to terminate the command and do it again with the next command/file
$ mode2 -d /dev/lirc0 -m > auto_21C_swing0_fan0
It could be necessary to gain super privileges to run this command ("sudo mode2 ...") and the lirc daemon can block the file, so it may be necessary to kill it first:
$ sudo /etc/init.d/lirc stop $ sudo mode2 -d /dev/lirc0 -m > filename $ [...] $ sudo /etc/init.d/lirc start
When reading the generated files, what we see is all numbers, organized in 6 columns. These numbers indicate durations in microseconds. The columns work in pair, so
740 1495 920 1345 735 1335
means : "the IR LED was ON for 740us, then OFF for 1495us, then ON for 920us, then OFF for 1345us, etc."
Exemple :
3523 1766 414 451 418 1312 423 448 419 452 418 452 428 443 417 453 418 457 418 452 418 452 416 454 419 452 417 453 417 1316 418 452 418 466 410 451 419 453 414 457 416 452 418 453 417 1316 418 1315 418 1320 426 443 419 451 419 1314 419 452 418 452 418 452 418 452 418 457 419 450 420 451 419 452 421 451 417 452 418 452 418 452 419 457 418 452 418 449 422 451 418 452 419 451 420 451 426 444 418 457 418 452 417 452 419 452 416 454 420 450 418 452 419 452 419 456 418 452 418 1323 411 1313 421 451 419 451 418 452 418 452 418 454 419 9997 3521 1764 417 452 419 1315 418 449 421 452 418 453 417 453 418 451 427 448 419 453 417 453 417 452 419 452 417 453 417 1317 417 451 419 456 419 451 420 458 411 452 418 452 416 455 418 1315 418 1315 418 1321 417 452 419 452 416 1318 418 452 418 451 419 451 419 452 418 457 418 452 418 452 420 448 422 451 419 457 412 452 417 452 419 457 418 1315 417 453 419 449 421 452 418 452 418 452 418 453 424 450 418 453 419 1314 418 452 418 452 418 1316 418 1315 417 453 418 465 410 452 419 452 416 453 418 452 418 452 418 452 418 453 417 1338 418 1316 415 1318 418 1315 419 1314 418 452 418 1315 419 449 421 1328 410 452 418 453 417 452 418 452 420 450 419 451 417 455 416 457 419 451 418 452 419 452 419 453 417 453 417 453 418 451 419 456 418 453 418 1315 418 1315 418 452 419 459 411 451 419 451 416 460 418 452 419 451 418 453 417 453 418 451 418 1315 419 1313 420 458 425 445 413 460 418 445 422 452 418 452 418 452 418 452 419 455 421 450 420 463 407 452 417 452 418 453 418 452 418 452 418 457 418 450 421 452 418 452 417 453 419 451 424 445 419 451 419 1321 417 453 417 454 416 452 418 452 419 452 418 452 418 452 418 468 408 452 417 1313 422 1314 418 452 420 451 418 452 418 452 419 456 418 453 416 454 418 1315 417 452 418 1315 418 452 418 1316 418 451 422
Ok, that seems insane :)
Note that the file will begin with a line with a single value : it is the time elapsed between the recording start and the arrival of the first IR signal. This line should be ignored.
Of course, as these are measures, with a time scale as small as the microsecond, all timings are different, which makes the detection of small differences between 2 commands impossible.
It can be observed that values are always close to 400 or 1300us, except for 3 (closer to 4400, 9900 and 1700). So what we'll do to make figures comparable is "round" the numbers to the closest of these 2 "reference" values (a spreadsheet is handy at first).
What this manipulation shows is that except for the 3 singular values the ON time is always 400us, what changes is only the OFF time.
Let's make the hypothesis that the OFF time is coding 0 and 1, and let's assume that 400us is for 0 and 1300us for 1. With this assumption it is possible to change each pair of columns to a single bit.
Let's also make an observation : the part between the 3 "singular timings" is always the same, in all the recordings. It can be assumed that :
- the part is an introduction, maybe identifying the remote or the Air Conditioner, and it will never change
- the different timings are Locks and separators between the introduction and the actual payload
It is therefore acceptable to take that part of the message as an invariant and not to study it.
For the ease of exploiting the data I wrote a small c program to round the values and transform it to binary digits. For ease of reading the code skips the intro part. Should you wish to use this code the timing values are defined in the beginning of the program, you will probably need to adapt it.
After compilation (gcc -o decode decode.c) you can use it on every data file :
$ ./decode auto_21C_swing0_Fan0 auto_21C_swing0_Fan0.decoded
Example with mode auto target temperature 25°C:
$ more auto_25.decode 01000000 00000100 00000111 00100000 00000000 10000000 01001100 00000001 11110101 00000000 00000000 01100000 00000110 00000000 00000000 00000001 00000000 01100000 00101010
Step 3: Exploiting the Data
OK, now what we have is a collection of data files containing bits (actually characters representing binary digits, which is technically different).
The use of a file comparison program will help in identifying which part changes for each parameter.
What we can see is not only one part changes but the ending part of the message also. Generally when communication is involved the data correctness is never guarantied so a checksum is usually used to ensure that no data has been corrupted. The checksum will be studied later.
ON/OFF:
Only one bit changes, the first of the 6th byte (or 40th bit). If 1 the command is ON, if 0 the command is OFF
AUTO/HEAT/COOL/DRY
3 bits change : bits 45 to 48 (see picture)
0000 = AUTO 1100 = COOL 0100 = DRY 0010 = HEAT
swing
bits 64 to 67:
1111 = swing auto 1000 = swing lowest 0100 = swing low 1100 = swing high 0010 = swing higest
Fan speed
bit 68 to 72:
1100 = lowest 0010 = low 1010 = medium 0110 = high 1110 = highest 0101 = auto
Options (Byte 13):
Powerful: 10000000 Quiet: 00000100 (and the Fan speed is set to minimum) None: 00000000
Temperature:
Here it becomes a little trickier because it would be nice to understand how the value is coded and not scan all possibilities.
We have sampled 16°C, 30°C, and 21°C. In binary :
16 = 10000 22 = 10110 30 = 11110
The correct zone for the temperature is not found using these values. But often hardware use bits in reverse order (Most Significant Bit or Least Significant Bit on the left of the number, also referred as Little Endian or Big Endian). If reversing the bits the values obtained is:
16 = 00001 22 = 01101 30 = 01111
This gives a match for the 3 values at bits 49 to 53. This is rather surprising as the value is not aligned with a byte (closest would be 6x8=48th bit). This means that when building a message the code will have to shift of one bit the temperature value.
Which consequently validates the first hypothesis concerning timing values used for 0 and 1 :)
Timer A:
The timers are coded in multiple positions: first avalue is used to indicate that the A timer is on, then a second one is used to indicate the timer value.
Timer active state can be found at the same byte as ON_OFF (6th byte, second bit, so starting from the beginning of the payload 41st bit).
So the Timer A is active if the byte is the 6th byte looks like :
x010xxx, the first bit being the ON/OFF bit.
For the timer duration, using the same encoding that with temperature and coding minutes and not hours (as the remote displays), the value can be found on the second half of the 12th byte.
Timer B:
Timer B is active if the 2nd bit of the ON/OFF byte is 1. As timer A is always ON when using the timer B, the byte looks like :
x110xxx, the first bit being the ON/OFF bit.
Ok, here I must admit that I failed to find the key to this value, maybe it is a delta between timer A and B, maybe another unit... Truth is: who cares about timers when the goal is to control it (automatically) from a computer ? :) Even timer A is not used in the end in my system, I was just happy to have found it.
Checksum:
Ah. Here is a value that cannot be disregarded. It is crucial to understand it.
After a few tests it appears that the checksum is for the payload part only (not including the introduction), and is the result of the simple sum of all bytes, keeping only one byte of the result (ignoring overflows). The trick is, of course, that this checksum is made by a Big Endian system, so every byte has to be reversed before being summed, then the result reversed again.
Step 4: Verifying the Analysis
The goal of the study is to be able to generate messages that the air conditioner will understand and accept. So the program joined will take arguments and generate a binary message. Now all that's left to do (until we have a working IR emitter) is to compare the message generated by the program and the recorded messages we had in inputs.
The values and position of each data in the payload is defined here.
Once compiled (gcc -o encode encode.c) this code should allow us to verify that the generated frame is equal to the one sampled
The encode program separates the bytes for easier reading.
$ more auto_25.decode 01000000 00000100 00000111 00100000 00000000 10000000 01001100 00000001 11110101 00000000 00000000 01100000 00000110 00000000 00000000 00000001 00000000 01100000 00101010 $ ./encode -m AUTO 25 01000000 00000100 00000111 00100000 00000000 10000000 01001100 00000001 11110101 00000000 00000000 01100000 00000110 00000000 00000000 00000001 00000000 01100000 00101010
That's all for this instructable, not much pictures or fun in it, I must admit, but there's more to come. Hope it might help someone.
Don't hesitate to ask for precision and comment.
2 People Made This Project!
- RicardoA168 made it!
- lowflyerUK made it!
50 Comments
1 year ago
Just FYI, I decoded a Lennox mini-split remote in much the same way as you have. (There was *NO* info on this format of IR commands to be found anywhere. Btw I'm using a Raspberry Pi, not an Arduino). The remote sends 6 byte packets - 5 data bytes and a CRC byte. It sends all 6 normally and then sends the same 6 inverted. If either transmission passes the CRC test then it should be obeyed. By the way one of your correspondents above was asking about sending IR from a Pi. The program send-lennox-code.c in https://gtoal.com/src/airco/ is quite short and does the job. You can assemble packets on the fly, you do not need to send only recorded signals. It's not essential, but if you can spare another pi, it's more robust to have the sender and receiver on different pies so they're not competing for CPU while timing transmissions. Also I found that a Pi4 supplied more current from its 5V pin to drive the IR LED than a Pi 2B did, which allowed the transmitter to be placed across the room from the Airco rather than be attached directly to it. I don't use LIRC at all, it's too much hassle as many have said.
4 years ago
Calculation off temperatures is incorrecte.
16 = 0000 = 16-16 = 0
22 = 0110 = 22-16 = 6
30 = 1110 = 30-16 =14
T'he fisrt bit is not signifitative..
Reply 3 years ago
Possible to post a fix for the encoder?
4 years ago
Hey, i've tried to decode my IR signal by following your instruction but somehow when i look the sequence, it has characters like £ or ¥, how do you solve this problem? thank you
7 years ago
Dear all,
I tried to decode ircode from my ir remote for my PANASONIC A/C. (it's not the same remote of you :( )
I did the same test 3 times and have three different results
The tests are to configure the remote control to 20 degrees and start the recording of infrared codes and press the button to set temperature above the temperature at 21 degrees.
First test
3500 1650 500 400 500 1200
500 350 500 400 500 350
500 350 500 400 450 400
500 350 500 350 500 400
450 400 500 350 500 1250
450 400 500 350 500 400
450 400 450 1300 450 1250
450 1300 450 400 450 400
500 1250 450 400 450 400
500 400 450 400 450 400
450 400 500 400 450 400
450 400 450 400 500 400
450 400 450 400 450 450
450 400 450 400 450 400
450 450 450 400 450 400
450 400 450 1300 450 1300
450 450 450 400 450 9950
3450 1700 450 450 450 1250
450 400 450 450 450 400
450 400 450 450 400 450
450 400 450 400 450 1300
450 400 450 1300 400 1300
450 450 400 450 450 400
450 400 450 450 400 1300
450 450 400 450 450 1250
450 450 450 1250 450 450
400 1300 450 400 450 450
400 450 450 400 450 450
400 450 450 1250 450 450
400 1300 450 450 400 450
450 400 450 1300 400 450
450 1300 400 450 450 400
450 1300 400 1300 450 450
400 450 450 400 450 400
450 450 400 450 400 450
450 1300 400 1300 450 1300
450 1300 450 1300 400 1300
400 450 400 1300 450 450
400 450 400 450 450 1300
400 450 400 450 450 400
450 1300 400 450 450 1300
400 450 450 1300 400 1300
450
Second test
3550 1650 500 350 500 1250
500 350 500 350 500 350
500 400 500 350 500 350
500 400 450 400 500 1250
450 400 450 400 500 350
500 400 450 1250 500 1250
450 1250 500 400 450 400
450 400 450 450 450 9900
3500 1700 450 400 450 1300
450 450 450 400 450 1300
450 450 400 1300 450 1300
450 1250 450 450 400 450
400 450 450 400 450 1300
450 400 450 1300 450 400
450 450 400 1300 450 450
400 1300 450 1300 450 400
400 1300 450 1300 450 1250
400 1300 450 450 400 1300
400
Third test
3550 1650 500 350 550 1200
3450 1700 450 400 450 1300
400 450 450 1250 450 1300
450 450 400 1300 450 400
450 1300 450 400 450 450
400 450 450 1300 400 450
450 1300 400 1300 450 400
450 1300 450 1250 450 1300
450 450 400 450 450 1300
400 450 450 450 400 1300
400 450 400 1350 400 1300
450
The goal is to control my air conditioning with my raspberry, but I can not interpret the raw code.
I don't undrestand why the results are not the same, and how interpret these codes?
On some sites I found the following results and on other sites I think of completely different values
3550 HDR_MARK
1600 HDR_SPACE
550 BIT_MARK
350 ZERO_SPACE
500 BIT_MARK
1200 ONE_SPACE
Thanks in advance for your help.
Reply 5 years ago
@psylo24
I have been gone for some time, but came back because I got a new air conditioner
You are probably long since gone, but on the off chance that you are getting email alerts, or that it helps someone else....
I did a quick check of your results, and all 3 samples were actually the same.
Remember, the numbers from lirc are (I think) the milliseconds of off and on time. A bit is a 1 if the off and on are the same, a 0 if they are not.
Looking at each of your results, they start with roughly a 3500 and a 1700. These are the 'sync bits' and you can toss them out. You will also notice that the sequence is repeated part way through each sample, indicating the end of one command, and the beginning of another.
Your 'baseline' is about 500. looking at the first few lines, you have the sync times of 3500 and 1650. Easy to spot, because the second is half of the first. The next two numbers are 500 and 400, roughly equal, so a '0'. Next two numbers are 500 and 1200, definitely different, so a '1'. It probably wont show up well here, but for the first part of your sequence, for all 3 samples, I get:
0100000000000100000001110010000000000000000000000000000001
Then about a third of the way through, you come to a:
That 9950, 3450 and 1700 are sync bits again. I toss them out and start decoding the rest of the message. For all three samples, I get:
10111111111110111111100011011111111111110110111110101011111111101011101011001111111111111000111111111000111111111111111101111110111111111111111110010100
You may have a remote that is sending multiple codes, or whatever, but if you want a starting point, I think you have consistent results.
I wrote a python program to read my codes in hex, since the irrecord lirc command seems to have lost the '-m' option that I used to use....
Nothing more than:
#!/usr/bin/python2
import subprocess, time
while True:
ct=0
code=""
raw_input("press key to start")
p = subprocess.Popen('timeout 5 mode2 -H default -d /dev/lirc0', shell=True, stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
for line in p.stdout.readlines():
ct=ct+1
if (ct>7):
x=line.split()
if (x[0]=="pulse"):
val=int(x[1])
else:
if (abs(int(x[1])-val)>300):
code=code+"1"
else:
code=code+"0"
retval = p.wait()
print str(temp) + " " + hex(int(code,2))
you'll have to fix the indents.....
Reply 5 years ago
correction. my code was backwards. the second part of the code should have been:
01000000000001000000011100100000000000001001000001010100000000010100010100110000000000000111000000000111000000000000000010000001000000000000000001101011
Hex: 4004072000905401453000700700008100006B
Big string. I'd say you have your hands full!
Reply 5 years ago
Facing the same issue.Did your problem solved ?please help me
5 years ago
This is great. I'll be using a different air conditioner and looking forward to giving it a crack.
I'll be using my air conditioner for non-conventional internal temperatures, which leads me to ask one question. Given that you reverse engineered the code for the temperature setting - can you tell the A/C to set the thermostat lower than the remote would have allowed? eg. my remote seems to limit the thermostat to 17 degrees C but I know the coolant achieve a lower temperature than that.
Reply 5 years ago
@SamP182,
I havent tried temperatures yet. But I can tell you my remote only allows 'sleep' settings in increments of 1 hour.
After decoding, though, I found it sends "60 minutes" instead of 1 hour. So I tried sending smaller values (5, 10, 30, 45 minutes) and it worked fine.
I suspect tho that there is a limit on what it will accept for temps.
Reply 5 years ago
Hi,
Thanks for you comment.
I think I recall having tried this, but without being able to measure the resulting temperature at the A/C output so I couldn't tell.
I moved in a new house recently so I don't have the system installed anymore. I'm affraid I can't test that again, sorry.
Anyway I suppose it's highly dependant on your A/C brand and model. I would include a protection to avoid going out of the target temperature envelop if I was a manufacturer.
5 years ago
Thank you for this extensive write up. I lost my remote and I was able
to write my own encoder for arduino. Now the A/C works again :)
5 years ago
I am studying M. TECH. So please guide me to complete the project
1) how to start thr project please guide me sir..
5 years ago
The main goal isn't using the decoded signal to transmit it from other than the original remote right? For that, would be only needed to record the original signal and try to retransmit it through the raspberry?
Fun read though, nice work.
5 years ago
I like your project very much and your description of the process you followed to decode the signals is super helpful. THANK YOU!
Gustavo.
6 years ago
Hello,
I'm trying to do the same but I'm facing some problems : how to get the gap parameter ?
I'm doing a :
sudo irrecord -a clim.conf > lircd.conf
to have a more readable file but it returns me :
irrecord: could not find gap.
irrecord: decoding of OFF failed
6 years ago
hey man, great tutorial,
im having trouble to control my panasonic ac, im using LIRC, and always having trouble to send the code, somehow the ac wont recognize any data i send, any suggestion?
6 years ago
This may be new since you wrote your article: http://removeandreplace.com/2016/06/17/universal-air-conditioner-remote-control-codes/
Reply 6 years ago
Thanks for the link. Seems like a nice product.
I doubt they describe the codes anyware though...
Anyway my goal was to control it from my PC, which I now do (and with the possibility to schedule it and make it a little more intelligent, like "turn it on the heat at 6PM but only if temperature is below a certain threshold" for instance).
Reply 6 years ago
I was hoping that it implied the information was out there, but you're probably right - it'll be proprietary :-( I wonder if they have access to the info from the manufacturers or if they reverse engineered a bunch of remotes like you did?
