Introduction: Ribbed Ombre Cowl
About: I love to sew, and other crafty thing.
This is is now my favorite scarf I have made so far. I wanted something that looked ribbed and something that I could crochet. Because prefer to crochet than to knit. It is a simply pattern to do, that creates a awesome ribbed cowl. It is worked in front post double crochet stitches, which gives it the ribbed look.
Supplies:
* cream, light brown-gray, gold brown(ish), and dark brown
worsted weight yarn
* size 5.5mm crochet hook
* scissors
Step 1: Pattern
As you crochet the rows will look like it's turning to the front, and that is OK because it will fix itself once you have more rows. On the wrong side (the inside) will began to form rows and on the outside it will form the ribs. Because of the rows on the inside, the cowl become really thick and squishy. I like to wear the cowl upside-down because the bottom edge has more give around my shoulders and neck.
sc: single crochet
dc: double crochet
sl st: slip stitch
ch: Chain stitch
yo: yarn over
Row 1:Chain 80 stitches, sl st to join, ch 1
Row 2: sc in each stitch, sl st to join, ch 2 do not turn
Row 3: dc in each stitch, sl st to join, ch 2 do not turn
Row 4: yo insert your hook from the front to the back of the first double crochet so that the stitch(post) is on your hook . At this point you should have two loops and a stitch on your hook. Yarn over and pull through so that there is three loops on your hook. Yarn over pull through two loops, yarn over again and pull through the last two loops until you have one loop left on your hook. That is your first front post double crochet stitch.
Repeat this front post double crochet all the way around.
80 stitches
Row: 5-7 repeat row 4 with front post double crochet in color one. (cream)
Row: 8-12 front post double crochet in color two (light gray-brown)
Row:13-17 front post double crochet in every stitch, sl st to join, in color three (tan)
Row: 17- 22 front post double crochet in every stitch, sl st to join, bind off in color four (dark brown)
