Introduction: Ribbon Zipper Bag (fully Lined)
Make fully lined ribbon zipper bags (for pencils, change or cosmetics) with this easy tutorial.
Step 1: Watch the Video Tutorial Here
Step 2: You'll Need
Scissors
1/4 yard lining
1/4 yard fabric
4 colors of 1" wide ribbon (about 12" of each color)
Sewing machine with zigzag stitch
Iron
10" zipper
Contrasting thread
Step 3:
Press your fabrics
Using a sheet of 8 1/2" x 11" paper as a pattern, cut out 1 piece of fabric and 1 piece of lining
Step 4:
Cut your ribbons to size and pin them in place on your outer fabric
Zigzag stitch them to the fabric
Step 5:
Place your zipper face down on the 8 1/2" edge of your fabric and stitch it in place
Take the other end of your fabric and stitch it to the other side of the zipper
Take your lining and place it on top of the zipper, lining it up with the fabric and stitch it across *You are sandwiching the zipper in between the fabric and the lining
Stitch the other side of the lining on the other side of the zipper.
Step 6:
This is what it should look like
Step 7:
Cut of the END of the zipper only
Stitch across that side of your bag using 1/2" seam allowance
Unzip the zipper to the middle of the bag
Stitch across the other side leaving a 2" hole (so you can turn it right side out)
Turn your bag right side out through the hole and stitch your 2" hole closed
Step 8:
Tuck the lining inside the bag and then press the fabric around the zipper!
You're done!
