Introduction: Ribbon Roses
Some time ago I wanted to make some fabric roses as a fun small present, but the only instructions I could find were somewhat fuzzy on the details. This is obviously not rocket science, but I thought I just might as well share some tips! This is my first instructable, so let me know what you think...
Step 1: Tools and Materials
- piece of ribbon, about 30 cm
- needle and thread
- piece of steel/copper wire, about 20-25 cm
- Green florist's tape.
- gluegun+glue
- scissors
- somewhere to work where you can spill glue
Step 2: Sewing
Luckily this doesn't have to be very neat! Get a piece of thread about as long as the piece of ribbon. Just loop around the end a couple of times to make a start (see the pic), then stitch very close to the one side. If you're done, hold the thread at the end with one hand, and push the ribbon back with the other hand, so that it bunches up. I found out you have to bunch it up quite a bit to get nice roses, otherwise the fabric is just gonna wrap around flat instead of standing apart. If you think you've bunched it up the right amount, finish the same way as you started. Since the sown part will be glued to the wire anyway, this simple way to fix the beginning and the end is good enough.
Step 3: Burn Your Fingers (glueing)
First glue the fabric to the the wire: flatten the end of the fabric, put the wire a little bit from the end of the fabric, put some glue around the wire and then fold over the end of the fabric.
Next wrap the fabric around the wire, after making sure it's bunched up evenly everywhere. You're probably gonna need to do this a couple times before you have the right shape. If you've found that shape, hold your flower a little above the edge at the stem, and then spread some glue in between the layers of fabric. This is the part where you're probably gonna burn your fingers pushing the layers of fabric gently together. I've not really found an ideal method or tool to prevent this... If the glue is dry, you can trim the extra threads from either the fabric, the thread or the glue.
The ribbon I used was coming apart at the end a bit, like you can see in the picture. Because I was giving the roses just as a nice gesture and I didn't expect people to keep these forever, I was fine with this. I just made sure the ends were ok at the moment I gave the rose.
Step 4: The Stem
Next up is the stem. Since the part where the fabric is attached to the wire is showing the sloppy sewing, start there by putting the end of the florist's tape over it, then wrap. Try to stretch the tape while wrapping around the base of the flower and the stem.l At the end of the wire wrap a little extra, and stretch it so far that it breaks. The florist's tape will stay in place without you needing to glue it if you stretch it while wrapping! If you want to you can probably make some leafs as well, by just wrapping the end of a leaf-shape to the wire.
Bend the wire a bit to make it look more organic and presto! You have a nice fabric rose.
Step 5: Give the Rose to Someone Nice :)
There are tons of occasions where you could give these, I use them mostly instead of cards because I always thought it a bit weird to give a card to someone when you meet face to face :). Giving a handmade rose, or even a bouquet with different colors, is much nicer!
15 Comments
9 years ago
I used duct tape and made it half the size a bit tricky but worth it!
12 years ago on Introduction
my version didn went so well:(
15 years ago on Introduction
I just made some, they are great! I just have to figure out how not to get burned by the glue, but it is still okay! thank you so much.
Reply 15 years ago on Introduction
yea, the glue sux :P but the surprised and happy face when you give these to someone makes up for it :).. cool that you made some!!!
you could put those rubber fingertip things that you use for sowing on when you spead the glue....
(oh, and how do you make the link write something else..)
http://www.fingergloves.com/ <<<These!
Reply 14 years ago on Introduction
When I use a Hot Glue Gun I wet my fingers with spit to make it not hurt AND the glue not stick to me :D
NEETO! This looks great! I hope mine come out as nice as yours did!
14 years ago on Step 4
how i can see the large image?
Reply 14 years ago on Step 4
Click on the thumbnail to see it as large as the main image on the page. If you want to see the image even larger, you can click on the small "i" in the top left corner, that takes you to a page with a link to the original image. hope that helps? :)
15 years ago on Step 3
You can seal the edges of the ribbon with a lighter, passing it over the edge once or twice. Or you can dab clear glue or nail polish on both sides.
the ribbon roses are REALLY COOL!!! as far as the fraying edges go, try burning them. I've tried it many times with the edges of ribbon for pointe shoes:)
tanx for the tip, i'll try that next time i'll make some :D
Wow! That's amazing!
They look.... so nicely done. You're AWSEOME!
Great job! +1 rating.
(added to favorites)
Thank you so much. Everyone I gave them to really liked them as well, so if you need to impress someone... :P
These are probably the coolest looking roses made by something else I have ever seen. It's insanely cool!
