Rice Heating Pad & Hand Warmers Gift
Intro: Rice Heating Pad & Hand Warmers Gift
These rice-filled heating pads and hand-warmers have made my life so much warmer and better! :) Surviving Wisconsin winters is really tough for me - but these little things make a huge difference. First, once made - all you need to do is throw it in the microwave for a minute or two and you're ready to go! They hold heat for quite a long time!
The small ones are great for pockets and the heating pads have multiple uses (for me anyway)- to warm my freezing hands, to soothe sore joints, to relieve neck pain, stomach aches, to defrost your windshield... and I've also used a little one to unfreeze the lock to my car door. I made a few of them in the past - but really rustic ones which didn't look nice enough to give as a gift to anyone.
So, I decided to upgrade them and make them with a removable fabric layer - so it can be washed easily and it'll last longer. They're very simple to make and I'll take you through the process here.
STEP 1: Materials Needed for Rice Heating Pads & Hand Warmers
Materials Needed:
- Regular Cotton Fabric
- about 1/4 yard per heating pad (full measurements are in the next step)
- hand-warmers each require two pieces of material 3 1/2 x 3 1/2 inches
- Snuggle Flannel Fabric - about 1/3 yard per heating pad (full measurements are in the next step)
- about 1/4 yard for the heating pad's removable layer
- hand-warmer's removable layer require a piece of material 4 3/4 inches by 8 inches wide
- White Rice - not instant
- 3 1/2-4 cups of rice per heating pad
- 4 1/2 to 5 tablespoons of rice per hand-warmer
- Sewing Machine
- Scissors
- Pins
STEP 2: Cutting & Preparing
The first thing we'll need to do is cut out the material. I am using some basic pink and blue plain cotton material for the rice packs. For the outer layer, we'll use the nice snuggle flannel fabric - and we'll get to that step later.
For the full heating pad, I folded the plain cotton material in half so I could cut through two layers at once. You'll need to cut out two pieces of material per bag, 13 inches long by 7 inches wide. Please note that this is not super long and if you want to make a heating pad specifically to go around the neck and further onto the shoulders, you'll want to adjust this and make it longer than 13 inches. For me, it can go around my neck but it's not super long.
For the hand-warmers, you'll want to cut out two layers of plain cotton material 3 1/2 inches wide by 3 1/2 inches high.
STEP 3: Sewing the Basic Packs
Now you'll need to take the two pieces of material and pin them together if needed and head on over to the sewing machine (or serger). Sew the material together along three edges of the fabric - leaving one side open. See image for clarification. Reinforce the stitches (especially on the large heating pad) to make sure it's extra strong and won't come apart! I used both my serger and sewing machine to sew the edges - either one would work just fine.
Once done, you can trim off any excess fabric and then turn the pads right-side out.
STEP 4: Filling Them & Sewing the End
Now it's time to fill them up with rice! In my photos, you'll see that I'm using brown rice in some of the heating pads. Please disregard that - and use white rice! I wanted to get rid of some rice we had and used a bag of the brown rice before getting to the white rice. When heated up, it has a bit of an unpleasant scent to it (although my son thinks it's fine). :)
*Warning: When sewing these, please read the directions fully and be extra careful to not get any rice underneath the area you will be sewing for your final seam. I did this one time - broke a needle and the sharp tip went flying out towards me and hit me. You don't want to get that stuck in your eye or ruin your sewing machine! Please be more careful than I was!
Filling with Rice
Filling with Rice
- Large Heating Pads
- I filled the large heating pads up with 3 1/2 to 4 cups of rice. I then folded the end seams inward and pinned it down. I also pinned the filled up pads as far down as possible (see image please) to try to prevent rice from spilling towards the area I would be sewing for the final seam.
- Hand-Warmers
- I filled the hand-warmers up with about 4 1/2 to 5 tablespoons of rice - then pinned and sewed the seam in the same manner as the large heating pad.
STEP 5: Cutting the Outer Lining & Pinning
In this step you'll need to do some more cutting. This time you'll be cutting out the snuggle flannel material for the outer layer of fabric, which will be removable. The outer layer will be sewn somewhat like a pillow case - for both the full-size heating pad and the hand warmers. You'll need to do a little bit of measuring yourself - with your rice packs and material to get it just right. I will explain how to do that.
For the outer layer of fabric for the full-size heating pad, cut out one piece of snuggle flannel material that is 28 inches long by 8 inches wide. This is one inch larger than the plain cotton material was when you cut that out.
For the hand-warmers, you'll need to cut out a piece snuggle flannel material that is 8 inches long by 4 3/4 inches wide.
Once you've cut these out, lay them out the long way (or as kids at school say - the hotdog way) and take the edges of the material on both ends and fold them in about 1/2 an inch and pin. See image.
Then, go to your sewing machine and sew a simple straight seam across, while removing the pins. Then trim the threads and we'll move onto the next step.
STEP 6: Final Pinning & Sewing
Now lay out your piece of fabric the long way, with the material right-side up - and place your rice heating pad in the center. Then fold one edge inward, and then the other edge in. The edges are supposed to overlap. Once snug and you like the placement and where the edges are overlapping, then place pins through the material at the corners, near where the rice pack ends. Then pin the overlapping layers together in the center (leaving the bottom layer alone). Once you like the placement, then carefully pull the rice pad out from within the center. Then, you can remove the pins that are in the overlapping area and pin them through all three layers. See images for clarifications - as I took a lot of photos!
The small hand-warmers should be pinned and sewn the same way.
Once you've completed the sewing, you can then trim off any excess material and turn the outer layer right-side out again. Then, take the rice packs and put them in the lining cases you just sewed and you are done! If giving these as a gift, you can tie a little ribbon around them with a nice bow.
See next step for more images of the final product & microwaving instructions!
STEP 7: DIY Rice Pack Heating Pads & Hand Warmers - Photos & Microwaving
You are done!
The large heating pads take about 1 1/2 to 2 minutes in the microwave to get nice and hot. The first time you heat it - you may want to just put it in for a minute, then check it and flip it if needed. Then if not warm or hot enough, add another minute. My microwave takes 2 minutes to fully heat the full size heating pad - and it's pretty hot (so be careful).
The small hand-warmers take only 30 seconds to a minute in the microwave to heat up. Enjoy!
37 Comments
AbigailW8 7 years ago
I made these tonight, hand warmer size. The instructions were great! I neglected to take a photo before wrapping them for a small birthday gift but plan to make more.
JoanneZ3 4 years ago
HollyMann 7 years ago
kkies 6 years ago
Claudia17 6 years ago
Do I have to make an outer bag out of flannel or could I use a normal patter out of like, T-shirt or something?
KerrianneA 7 years ago
Thanks for the tips!
Lacey12 7 years ago
Should I only use cotton thread in terms of microwave melting concerns? I find that all of my thread spools are either polyester or cotton convered polyester. :/
Betty Priest 7 years ago
Have made these to sell at a fete, but when testing the heating in my microwave, sparks started to fly. Turned off and will not be calling them hand warmers anymore, but pattern weights. Any suggestions?
KitMinden 7 years ago
They can be used as ice packs for people in pain so not just paper weights. Some synthetics cannot be microwaved and some painted fabrics cannot be mw also.
KristinaF16 7 years ago
Supergirl22 8 years ago
wow these are awesome I love them the rice smells a bit but nothing a little lavender won't fix thank you!!!! You've made my winters a whole nicer
HollyMann 8 years ago
No problem..I have one with me at all times!
vaspider 8 years ago
If you use a full-cotton t-shirt, this is a good way to salvage a favorite t-shirt which doesn't fit anymore or which has worn out at the sleeves.
awesome idea :)
naynay66 8 years ago
thank you!
tincanpixie 8 years ago
Definitely don't need to cook it...and it's not a stupid question :)
swimstar243 8 years ago
