Introduction: Ring Toss
This instructable will show you how to make a ring toss.
Computer
Fusion 360
Step 1:
You want to start out with a base 100 mm in length and 100 mm in width.
Step 2:
For step 2 you want to make the rings that will be used for the ring toss. The ring's inner diameter is 30 mm. The torus diameter is 5 mm
Step 3:
For this step, you want to use some of the rings and cut them into the base. This will make it so that when you are not using the rings then you have a place to keep them.
Step 4:
For this step, we are making the piller that the rings will slide onto. make a cylinder that is 20 mm in diameter and a height of 120 mm
Step 5:
This is the final product.
