Introduction: Ring Tutorial - Riveted Rock Band From Beaducation - Step by Step Jewelry Making Video Tutorials
Create unique and beautiful rings! This class teaches texturing, shaping and riveting as well as creating nail head and balled headpins. Transform flat wire into ring bands and individualize your piece with favorite sayings and design stamps. Lastly, rivet on a gemstone to complete your creation.
This class has a running time of 1 hr, 11 minutes.
Pre-requisites
Making Your Own Balled Head Pins
TOOLS
Fire extinguisher
Noncombustible work surface
Large Wrap and Tap Pliers - You may also use a ring mandrel or large dowel to shape the band.
Table Vise- We carry a handy table clamp vice. If you already have a vice on your workbench, it will work just fine.
Lindstrom Chain Nose Pliers RX7893
Cutter - Fine Tip Flush Cutter
Screw Down Hole Punch, 1.6mm & 2.3mm holes
Flat Sanding Sticks, Set of 8 - Or use 400 and 600 grit sandpaper.
Replacement Tip, Large Diamond Bead Reamer - If yours goes dull. You can also use it in a pin vice to make a hand-held reamer.
Small Files, Set of 6- For filing out the hole for the rivet. You can also use the Electric Bead Reamer for this step.
MATERIALS
14g Fine Silver, Round, Dead Soft Wire - 3 ft
Sterling Silver Flat Wire 5mm x 1.5mm (priced per ft)
Sterling Silver Flat Wire 7mm x 1mm (priced per ft)
Pearl with 14 Gauge Hole, White
Bead with 14 gauge hole or larger
OPTIONAL
As always, if you have any questions or need any help, please contact us via Instagram, Facebook or email us directly, cs@beaducation.com.
