Introduction: Pet Robot
I always wanted a pet robot--one that runs around and takes care of itself.
Roamer 2 wanders about, detecting objects using sonar and her front bumper. She mostly stays out of trouble.
Her maximum run time is about 11 minutes, but she starts hunting her charger (using a Pixy camera and Arduino) after 4 minutes. Charge time is around two minutes. Because she is powered by super capacitors, she can charge and discharge tens of thousands of times (at most any rate) without degradation of the capacitors. The charging station is a 12" x 12" metal plate with a pole in the center. Roamer 2's front bumper contacts the pole and a spring (lowered by a servo motor) contacts the metal plate. A bench power supply, set at 12 volts (max) and 1.6 amps (max) supplies the energy.
500 farad, 2.8 volt capacitor
Lever switch, momentary
photo resistor
(2) Arduino
Arduino motor shield
Three amp diode
(4) 4.7 k resistor
breadboard
aluminum duct tape
spring, 5.5 mm x 38 mm
sheet steel
Bench power supply
Wire, solder, 3mm screws
3d printed parts (files available in this Instructable)
Gear
Servo motor
Pixy camera
Ultrasonic module
Relay module
Step 1:
The schematic is shown here. There are two Arduino processors. One manages the Pixy camera and the ultrasonic transducer, sending results to the motor control Arduino.
Step 2:
Print the 3d files.
Step 3:
Install the motors in the base.
Step 4:
Attach the spring power pickup to the servo motor.
Step 5:
Installl the servo motor and capacitors.
Step 6:
Place the tires (vacuum belts) on the wheels.
Step 7:
Attach the switch to the switch bracket. Add the bumper and wheels to the base.
Step 8:
Add the caster wheel to the rear of the base.
Step 9:
Add foil tape to the front bumper.
Step 10:
Add the camera and ultrasonic transducer to the body.
Step 11:
Drill a hole in the center of the steel base plate. Install the pole (wrapped in metal foil). Add the target color paper to the pole (target color should be something not visible any where else within the habitat).
Step 12:
Set the voltage on the power supply at 13 volts, current at 1.6 amps. Let your new pet roam!
