Introduction: Roberts R747 - DIY Raspberry Pi Internet Radio/streamer
Roberts R747, great radio from 1990. Fully working in very good condition. Found it on antique sale after a long hunt for something like this.
I have a spare Raspberry Pi model B V1 home as a spare and it was just catching dust for some years as I couldn't decide what to do with it.
EDIT 1: 13/12/2016 changed OS to MoOdeAudio as its prooved to deliver best sound quality and performance
EDIT: OS now changed to RuneAudio which is better maintained
Original old OS not used anymore (Than I came across this piece of software called "Pi MusicBox")
And I finally found a use for my RPi
This Pi MusicBox offers:
- Standalone Spotify, Google Music, SoundCloud music player
- Remote control it with a nice browser-interface, or with an MPD-client
- Web Radio, Internet radio
- AirTunes/AirPlay streaming
- Play music files from the SD, USB, Network.
- and much more...
So I wanted to combine the great Roberts radio, RPi and this piece of soft. Mine main goal was to keep the radio fully functional and intact. So no extra bits, no drilling, no outside wires, etc.
There is not much room inside of the radio so it wasn't an easy task and I had a few challenges. But that was the best on this little project.
So after I opened and took it apart for a first time, first I thought I would not be able to squeeze all in.
But after a while I managed to find a spot for RPi and power supply.
The RPi is fitted on double sided tape and without any casing as there was simply no room for it or for any fittings. I have managed to took apart and ordinary wall charger and used just the electronic board which is hard wired on both sides. It is soldered to the mains of the radio and than on the other sides its soldered to the RPi directly as, once again, there was no room for USB connector.
Than I had to find a way to switch between radio and AUX (RPi). The solution was pretty simple. There is a connector for external aerial. So I have split the cable from 3.5mm Jack and soldered that to this aerial (which is disconnected inside) and PCB. So this way I do not need an extra switch for switching between radio and AUX(RPi). Every time I want to switch to AUX(RPi) all I need to do is to shorten this aerial connector. The easy way to do so is just by plug in the blank coax connector which is shortened inside.
So all challenges solved.
All wired, placed, fitted inside. No visible changes from outside
Step 1: Left Side
You can see the left panel here.
From top
- 75 Ohm external aerial socket
- 5 pin AUX
- 240V
Step 2: Stream From Mine OnePlus One Android Phone
Step 3: Opened
Took all apart and was looking into it what and how to do for a first time
Step 4: AUX
3.5 Jack soldered directly onto PCB to AUX input
Step 5: RPi Wrap
Raspberry Pi
Because of the little room inside of the radio, I couldn't used any case for RPi.
So the solution was a piece of flexible plastic sheet on double sided tape and rubber bands
Step 6: RPi Pads
Little foam/rubbery pads on double sided tape
Step 7: RPi Fitted Inside
RPi fitted inside on only available space holding by double sided tape.
Really tight, there is no room left. Not really visible but the GPIO port of RPi is just about 5mm from radio transformer at the bottom
