Introduction: Roblox Ip Puller
This is a roblox ip puller
Necessary Software:
Notepad
Cmd
A Computer (Presumably a Windows)
A Target
Step 1: Code
echo off
cls
color 02
title Roblox IP Tracer
:top
echo ....................................
echo.
echo The best Roblox Ip Address tracker!
echo. echo ....................................
echo.
echo 1) Tutorial
echo 2) Bot
echo 3) Save IPs
echo 4) IP Pinger/DDOS
echo 5) Troubleshoot
echo.
echo.
set /p M=type here:
echo.
if %M%==1goto tu
t if %M%==2 goto bot
if %M%==3 goto save
if %M%==4 goto ippinger
if %M%==5 goto troubleshoot
:tut echo 1. go to the roblox website on computer
echo.
pause
echo 2. copy the id from the link (the random numbers... for example https://www.roblox.com/users/XXXXXXXXX/profile)
echo.
pause
echo 3. copy it into the bot and wait. When its done it will come up with something that says "Tracing route to XXX.XXX.XXX.XX over a maximum of 1 hops"
echo NOTE: The 1 Ip that shows up under that ip is YOURS. dont send that one to anybody. only the one above. echo. pause
cls
goto top
:bot set /p id=type ID into Here:
echo The bot should now display The Ip Address. Refer to the tutorial for instructions.
pause
cls
goto botdone
:botdone echo The Bot Takes A Second! Sorry For That tracert /h 1 %id%
pause
cls
goto top
:save set /p ipaddress=Type IP Address Here: %ipaddress%> savedips.txt
goto top
:ippinger
cls
echo this is the ip pinger built into this
echo Code from: SokoPinger: SourceForge
set /p IPP=Type IP you want to Ping here:
:repeat PING -n 10 %IPP% | FIND "TTL=" ping -t 2 0 10 127.0.0.1
>nul goto repeat
:troubleshoot echo Sometimes "Terminate Batch File Y/N?" Will come up.
echo this is nothing. just type "N" and enter.
echo.
echo if you dont specify a ID Or IP into the Trace Console. A message will come up. echo This is also nothing. Dont worry about that. its just a error message. pause
cls
goto top
Step 2: Explanation (Not Necessary)
The bot uses tracert to trace a route to (IP) which is your victims ip
your ip will show up under it. dont ddos that one or your gonna have a bad time.
also that was an undertale reference. god what have i become. . .
