Introduction: Robo-cycler
Robo-cycler is a robot designed to detect different materials like metal and nonmetal materials. We use a Redbot, which is a robotic development platform that allow us to integrate sensor for material detection and program them in Arduino environment.
The Robo-cycler has a neuronal network that is trained to receive inputs from sensors and provide the expected material as an output.
Robo-cycler is intended to identify recycling material and help users dispose them in the right recycling place.
Step 1: What Is Needed?
Hardware:
- Metal Sensor (Blue): DC6-36V NPN NC 5mm Inductive Proximity Sensor Detection Switch LJ18A3-5-Z/AX
- Metal and Non-metal Sensor (Orange): DC6-36V 300mA NO 3-wire Capacitance Proximity PNP Switch Sensor Detector 1-25mm
Buetooth Bee:BTBee HC-06
Redbot
Software:
- Arduino IDE
- Processing
Step 2: Assemble the Sensors
Each sensor is assembled in the RedBot Mainboard. Robo-cycler, uses port A2 for Metal Sensors (Blue) and port A3 for Metal & Non Metal sensor. The SW Serial port is used by the Bluetooth sensor.
Step 3: Inputs and Outputs
Robo-cycler receives 2 inputs from the two sensors:
- metal sensor (blue)
- metal&non-metal sensor (orange)
and returns a binary output depending on the material sensed.
Please see the picture attached as reference.
Step 4: Code
In this section, we summarize the ARDUINO code used to train our RedBot with a Neural Network and a PROCESSING code to handle the RedBot from a remote controller.
The Arduino CODE is embeded in the RedBot. The Processing is in a remote controller (PC). Both devices communicate via Bluetooth.
Arduino Code:
Neural Network Pseudo Code:
- Train the Neural Network based on pre-processed training data.
- Initiate the sensors
- Loop until exit program
- Detect remote control input (enter key)
- W = Backward.
- S = Forward.
- A = Left
- D = Right
- Z = Sense Metal Sensor (Blue)
- X = Sense Metal&NonMetal Sensor (Orange)
- C = Activate Neural Network
- Write Neural Network results in serial port.
Neural Network Back Propagation (NNBP) Functionality:
The NNBP is implemented using two neurons. Each neuron represents a sensor's input. The sensor's input is a binary (0, 1023) that reflects the absence or presence of the material.
Please refer to the code attached - RedBotArduino.cpp
The Remote Controller code is implemented so users can handle the RedBot movements from a keyboard using the up, down, left, right keys.
Please refer to the code attached - RemoteControl.pde
Step 5: Pre-work
- Make sure you have all your hardware and software components described in step 1.
- Make sure all your sensors are properly installed as described in step 2.
- Open Arduino IDE from your computer and save the code described in step 4.
- Turn on the Redbot switch.
- In Arduino IDE, go to Tools > Port COM6 and make sure COM6 is selected. Please see screenshot (a.)
Step 6: How to Use It? RedBot Commands
To handle RedBot, you will a series of commands to initiate the Neural Network training, sense the materials with the Metal (Blue) and Metal & Non-Metal sensor (Orange), activate the Neural Network, and clean the training variables.
This chart describes the commands and the expected result of each of them.
Step 7: Results
This video shows on high level of how the RedBot works and some materials that can be detected or not.
