Introduction: Robot
Hi,
Today I'm going to teach you how to make the outside of the a robot. If you make one and 3d print it you could add some robotic things in it to make it move.
Step 1: Robot Head
First create a square, four cylinders, and a round roof. Then make two of the cylinders smaller. And put two of the smaller cylinders on top of the other two cylinders. Then put the cylinders and the round roof on top of the square.
Step 2: Neck
Create a rectangle and a cylinder and put the cylinder on top of the rectangle.
Step 3: Arms
For this step you will need three rectangles. Make one of the rectangles small and the other two about the same size. Then combine all three rectangles together to form a arm, and repeat again to make the other arm.
Step 4:
Look at the pictures and create the parts.
Step 5: Combine
Then combine them together so it will look like this.
Step 6: Holes
Then add two cylinder holes into the robot part shown in the picture.
Step 7: Legs
Next, you will need three rectangles and two 2D squares. Then combine the three rectangles and put the two squares next to each other.
Step 8: Combine
Then combine the legs to the body.
Step 9: Combine
Then finally combine all the parts together and make a robot.
