Introduction: Robot Artist
The final project is a car that you can use to spend a good time, with or without company. It is recommended that the construction process is done with the help of an adult, to prevent cuts from the cutter or burns from the silicone gun or the soldering iron.
This can be artistically complemented with markers, paint, paintbrushes...
To know its creation read all the following processes, complemented with images of the results.
At first you have to pick the material that you want to make the surface of the car. When you decide what material you will use, you make the surface of the car.
Step 1:
You will need:
- 3 different cables
- 2 engines
- 2 or 4 wheels
- Battery holder
- Soldering iron
- Silicone glue
- LEDs
- 1 pen
- Cardboard
- Tin
- Batteries
First of all we took our piece of cardboard and cut it out. Then we grabbed two wheels and two engines and glued the wheels together with the engines. Then we cut another piece of cardboard for the remote control. We took two switches and put them on the cardboard surface.
After this we took three different cables: 2 for the positive and then 1 for the negative.
We put the three cables in the energy of the motors, the red cable which is negative. You solder it on the bottom part of the engine, you do the same with the yellow one on the other engine. When you have done this the blue cable which is positive you solder the same cable in both engines, it has to be the same cable.
