Introduction: Robot Birthday Cake | Crochet Pattern
What better way to celebrate the Instructables Robot’s birthday than with a cake…a crochet cake! This playful project combines my love of crochet with a whimsical design that captures the charm of the mascot. Using soft, chunky yarn, you’ll create a squishy amigurumi cake that looks just like the robot—complete with antennas, a cheerful face, and even a “20” to mark this special occasion.
Beginner-friendly and quick to work up thanks to chunky yarn, this project makes a perfect decoration or cuddly keepsake. Follow the step-by-step instructions, and by the end you’ll have your very own plush robot cake to show off. Let’s get crocheting!
(All yarn is chunky/super bulky unless stated otherwise)
  1. Yellow – Main Body/Cake
  2. Black – Side antennas, Mouth, Unibrow, Base Stripe, Number 20
  3. Red – Icing, Ears, Eye Rings
  4. Gray – Robot Buttons and Candles
  5. Orange – Candle Flames
  6. Black worsted weight yarn – Embroidered control box
Crochet Hook: Size 8 mm (or size recommended for your chunky yarn).
Stuffing: Polyester fiberfill (plenty—chunky yarn projects need more).
30 mm safety eyes
Large Tapestry Needle
Stitch Markers (Optional but helpful for keeping track of rounds. I generally just use a small piece of yarn as I find it to be much faster and simpler.)
Scissors
White paint marker
Abbreviations:
ch – chain
sl st – slip stitch
sc – single crochet
hdc – half double crochet
inc – increase (2 sc in the same stitch)
st(s) – stitch(es)
BO – bobble stitch
Note on Bobble Stitches: For this project, each bobble stitch is made with 3 double crochets (dc) in the same stitch, not 5 as in a standard bobble.
Step 1: Base Cake (Body)
R1. Using chunky yellow yarn, Ch 2. Sc 6 in the second ch from the hook (6)
R2. Inc in each stitch around. (12)
R3. (1sc, inc) x 6 (18)
R4. (inc, sc 2) x 6 (24)
R5. (sc 3, inc) x 6 (30)
R6. (Inc, sc 4) x 6 (36)
R7. (sc 5, inc) x 6 (42)
R8. (inc, sc 6) x 6 (48)
R9. (sc 7, inc) x 6 (54)
R10. (inc, sc 8) x 6 (60)
R11. (sc 9, inc) x 6 (66)
R12. (Blo) Sc in each stitch around. (66)
Change to black yarn.
R13. (Blo) Sl st in each stitch around. (66)
Change back to yellow yarn.
R14. (Blo) Sl st in each stitch around. (66)
R15. (Blo) Sc in each stitch around. (66)
R16-R22. Sc in each stitch around. (66)
Tie off leaving a long yarn tail for sewing to the top.
Step 2: Base Cake Top
Tie off and weave in the yarn tail.
Step 3: Icing
Attach red yarn to the top edge of your base cake. Then while working in only the front loops of the base and top (BO, sl st) x 33 (66)
(Make sure to stuff your cake before sewing completely closed)
Once finished tie off and tuck in the yarn tail.
To crochet the icing on the bottom of the cake:
Work in the front loops of R11, use red yarn to (BO, sl st) x 33 (66)
Step 4: Top Cake Layer (head)
R9. (Blo) Sc in each stitch around. (48)
R10 – R16. Sc in each stitch (48)
Tie off and leave a long yarn tail for sewing.
Step 5: Attaching the Second Layer (Head)
Start sewing the top cake layer to the base, keeping it centered. Before closing completely, add stuffing, then finish sewing shut.
Step 6: Eyes
  1. Use a white paint marker to add a bold dot to each safety eye.
Eye Rings (Make two)
R1. Using chunky red yarn, Ch 2. Sc 6 in the second ch from the hook. (6)
R2. (2sc, inc) x 2 (8)
Tie off and leave a yarn tail for sewing.
  1. Insert the safety eyes into the eye rings and secure.
  2. Sew the eyes to the top cake layer (head) between rounds 11 and 14, about 2sts apart.
Step 7: Embroidering the Mouth and Unibrow
  1. Using chunky black yarn, embroider a mouth between rounds 15 and 16. Make it about 10sts wide and position it slightly to the left of the eyes.
  1. Embroider the unibrow between rows 9 and 10, about 10sts wide. Place it slightly to the right of the eyes.
Step 8: Robot Ears
Ears (Make two)
Tie off leaving a yarn tail for sewing.
Step 9: Attaching the Robot's Ears
Sew each ear to the sides of the head, placing them between rounds 10 and 14, about 5 stitches out from the eyes. Make sure both ears are even before securing them fully.
Step 10: Antennas
Antennas (make two, worked in rows)
R1. Ch 5, turn. (5)
R2. Hdc in the second ch from hook, then hdc in each of the next 3 sts. (4)
Fasten off, leaving a tail for sewing. Fold the strip in half lengthwise and whip stitch the edges together to form a tight tube shape.
Step 11: Sewing the Antennas to the Ears
Using the yarn tail, sew the antenna to the center of the ear. Repeat for the other side. Make sure the antennas are centered to the ear.
Step 12: Front Panel Buttons
Front Panel Buttons (Make three)
R1. Using chunky gray yarn, Ch 2. Sc 6 in the second ch from the hook. (6)
Tie off and leave a yarn tail for sewing to the body.
Step 13: Attaching Buttons
Sew the buttons to the front of the base cake between rounds 19 and 21, each about 2sts apart.
Step 14: Embroidering the Front Control Panel
Front Control Panel: Using worsted-weight black yarn, embroider a rectangle on the front of the robot between Rounds 15 and 18, approximately 13 stitches wide. Then, embroider a diagonal line from the top right corner to the bottom left corner of the rectangle.
Step 15: Candles
Candle Stick (Make two)
R1. Using chunky gray yarn, Ch 6. Turn. (6)
R2. Hdc in the second ch from the hook. Then Hdc in the remaining 4sts. Ch 1 and turn. (5)
R3. Hdc in each stitch across.
Tie off. Then fold the rectangle in half lengthwise and sew together the two edges. (Leave extra yarn for attaching the candle to the cake.)
Candle Flame (Make two)
R1. Using chunky orange yarn, Ch 2. (Sc, Hdc, Sc) in the second chain from the hook.
Tie off and attach to the top of the candle stick.
Step 16: Number 20 Cake Topper
(Each line represents one stitch)
Number 2
Ch 11
sc in second ch from hook
sc
skip one ch
3sctog
skip one ch
sc
sc
2 sc in next ch
2 sc in next ch
sc
sc in side of last stitch (to curve bottom)
ch 3, sl st back into same st (makes bottom point)
Finish off with a long tail for sewing
Weave in short end
Use tail to sew on
Number 0
Ch 9
sl st to first ch to form a ring
sc in same st
sc
2 sc in next st
sc
sc
2 sc in next st
sc
sc
join with sl st to first sc
Step 17: Sewing on the Candles and Cake Toppers
Using a yarn needle and the leftover yarn tails, sew the number “20” in the exact center on top of the cake/head. Then, sew a candle on each side of the numbers while making sure everything is evenly spaced and aligned.
Step 18: Congratulations!
Congratulations! You’ve completed your very own crochet robot cake, perfect for celebrating the Instructables Robot’s birthday—or just for fun! Take a moment to admire all your hard work and creativity.
Your robot cake is ready to join the party—or just sit proudly on your shelf!
