Introduction: Robot That Automatically Fills Up the Dogs Water
A dog is a man's best friend. But the question is, "what is a dog's best friend?" Meet Squirtle: the robot that automatically fills up the dogs water. You should watch the video down bellow so you can see the robot in action.
So, in order to build this you need the Super Learning Kit from LavfinTech.com, this miniature water pump and a 1 gallon water jug. You can find all of these on Amazon.
Step 1: Add the Arduino
First, you are going to pull your Arduino and your bread board. Then you are going to hook up a male to male wire to the 5 volt port and a male to male wire to the ground port on the Arduino with male to male wires. Then plug the 5 volt and the ground into the positive and ground on the breadboard.
Step 2: Add the Servo and Water Level Sensor
Next, pull out the servo and the water level sensor. On the water sensor attach male to female jumper wires. Then, on the servo attach male to male wires.You are then going to hook up the negatives and positives from the servo and the water level sensor anywhere on the negative and positive ports on the breadboard.
Step 3: Finish the Servo
Then plug in a male to male wire to port 9 on the Arduino and plug that in anywhere on the breadboard that is not in the negative or positive columns. After that, plug in the leftover wire from the servo (the yellow one) to the direct right of the other wire from port 9.
Step 4: Finish the Water Level Sensor
Then you are going to take a male to male wire and attach it to the A0 port on the Arduino. Put the wire anywhere on the breadboard that is not in the negative or positive columns. Then attach the leftover wire on the water level sensor to the direct right of this wire.
Step 5: Power
If you want you can make it battery-powered by plugging the Arduino into this circuit and plugging a 9-volt into that. But I recommend just using an outlet.
Step 6: Add the Code
I have pictures of the code here but here it is so you can just copy and paste it.
#include <Servo.h> // Make sure to include the Servo library
Servo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
int adc_id = 0; // ADC pin to read from
int HistoryValue = 0; // Variable to store the last ADC value
char printBuffer[128]; // Buffer for printing
bool hasMoved = false; // Flag to check if the servo has moved
void setup() {
myservo.attach(9); // attaches the servo on pin 9 to the servo object
Serial.begin(9600); // Start serial communication at 9600 baud
void loop() {
// ADC reading logic
int value = analogRead(adc_id); // get ADC value
// Check if the historical value has changed significantly
if (((HistoryValue >= value) && ((HistoryValue - value) > 10)) ||
((HistoryValue < value) && ((value - HistoryValue) > 10))) {
sprintf(printBuffer, "ADC%d level is %d\n", adc_id, value);
Serial.print(printBuffer);
HistoryValue = value; // Update the history value
// Start the servo motor if the historical value goes below 250
if (HistoryValue < 250 && !hasMoved) {
for (pos = 0; pos <= 130; pos += 1) {
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 130; pos >= 0; pos -= 1) {
myservo.write(pos); // tell servo to go back to position in variable 'pos'
hasMoved = true; // Set the flag to true to prevent repeated movement
// Reset the flag and move the servo again if the historical value goes above 249
if (HistoryValue > 249 && hasMoved) {
hasMoved = false; // Reset the flag to allow movement again
Now in order to download it you have to have an Arduino I.D.E. I'm not going to walk you through how to download it because there are hundreds of you tube videos about it and it is a bit different for each computer. Oh and make sure the code starts from the second line or else it won't run. Then you can download the code to the Arduino.
Step 7: Attaching the Servo
At this point, you are going to hot glue the servo to the corner where it can press the button on the water pump. Before you hot glue it you need to make sure it is facing the right direction. When you give power to the Arduino, the servo motor should move unless the water level sensor is in water. The other thing that you need to do is to take the stickers off the servo before you hot glue it.
Step 8: Finish the Wiring
Then you need to add more male to female wires to the water level sensor to make it longer because this needs to go in the dog bowl.
Step 9: Hot Glue
You need to add hot glue to the front and back of the water level sensors. You need to make sure no hot glue gets on the copper strips because then the water level sensor won't work. Then hot glue all of the wire connections including the bread board and the Arduino. That way they won't come off.
Step 10: Pump Meet Water Jug
Then, using hot glue, attach the water pump to the lid of the water jug.
Step 11: Put It All Together
Next, hot glue a piece of cardboard onto the water jug. Following that, use the peel and stick on the breadboard to stick it to the cardboard. Then hot glue the Arduino to the side of the water jug.
Step 12: Customization
The next step and the most important step is to add on some googly eyes and you're good to go.
Step 13: Finish
Lastly, you need to hot glue the water level sensor to the top of your water dish. You will need to scratch up the spot you hot glue the sensor on and make sure the sensor is dry.
