Introduction: Robotic Line Follow Robot
i wanted to create this project to follow an line and then i could put an bin on top of it and it could go around and collect rubbish when i have gests over
supplies
hot glue gun
soldering iron
screw drivers
wire in diffrent collures
moter controller
2 moters dc https://amzn.eu/d/hAGeaVi
3d printer + filliment
wire cutters
wire stripper
pi peco
programing skills
tracking sensors https://amzn.eu/d/4sywABF
ball castors https://amzn.eu/d/7JQk8Um
Step 1: Printing the Body
print the main body and the nose cone
Step 2: Gluing the Parts Together
i used hot glue to glue it together then i used an old soldering iron and filiment to bond the prints and fixed up any prinnting errors
Step 3: Installing Sensors
i used some bolts and an alon key to secusre the sensors in place 2 link in supplyies
Step 4: Insinstalling the Ball Castor
i used hot glue to install it i had to cut it down an little bit
Step 5: Installing Moters
printing and gluing the moter blocks to the moters
Step 6: Soldering the Wire to the Moters
first get the wire cut to length of what you need then cut 4 2 for each moter i used the wire stripper to strip the end of the wire then soldered it and tined it
Step 7: Wire
putting the wire thrugh the slot
Step 8: Wires
first i striped back an old usb cable then i wired in the moter cables posive and negotive then i conected the singil cables to the pi peco and then coded it i used chat gpt and i did not post code due to you migt want the robot to do more that i wanted for full costibility
