Introduction: Robotic Styrofoam Hand
This will teach you how to make a styrofoam hand
Styrofoam, Exacto knife, Elastic Bands, Sanding block, marker, needle, fishing line, paper clips, hot glue gun, ruler.
Step 1: Draw the Shapes Onto the Styrofoam
Before drawing the fingers, you have to measure them to measure each finger use your ruler and press it against any of the fingers.Write your measurements down. Take your marker and draw out the measurements of the pinky finger, ring finger, middle finger, pointer finger and thumb. You will also need to draw your palm and wrist.
Step 2: Cuting the Finger
after you have drawn your fingers, palm and wrist. Cut the outline of all of your drawings out with your exacto knife.
Step 3: Cut Triangles
When your done cutting out all your fingers, cut small triangle based prisms out from the corners of the square based prisms.
Step 4: Sand the Fingers
After cutting the corners, use your sanding block to round the corners you just cut. Also you have to round the top to make a smooth half sphere
Step 5: Segment the Fingers
Next you need to measure the 3 diffrent segments of the fingers. After your done measuring cut the segments out of the whole fingers according to your measurements
Step 6: Making the Fingers Bend
Next you have to make them bend forward, to do this cut a maximum angle of 45 degrees off each end of the finger, for the bottom segment of the finger on the top, cut a 45-degree angle, for the middle segment, on the top and bottom, cut a 45-degree angle, for the top segment, on the bottom, cut another 45-degree angle
Step 7: Making the Finger Retract
So we can bend the finger, but we need it to go back to its original position, how do we do this. All we need to do is attach the elastic bands to each of the finger segments
Step 8: Attach the Fingers to the Hand
take a needle, thread the finger segments through the middle of each segment then from the top of the hand, thread the finger through the position that the finger should be in and come out palm of the hand.
Step 9: Coding and Wiring the Arduino
Click this tinkercad link and copy everything you see including the code onto the Arduino
Circuit design RoboticFoamhand - Tinkercad
