Introduction: Rocket Brand Studios Medium Tank
This is the assembly instructions for the Medium Tank from Rocket Brand Studios. This is a great little robot kit, and can be purchased as a complete kit or as a rolling chassis, ready for the micro controller of your choice --Arudino Uno, Duemilanove, Picaxe 28 board, or Gadget Gangster Propeller Board. The Medium Tank comes in lots of super-duper colors (and colours!) so be sure to stop by the website to see what is available.
Step 1: Prepare
Alright there, Skippy --Unwrap everything and get ready to get going.
You will need:
You will need:
- Little screwdrivers
- X-acto knife
- Soldering iron and small solder
Step 2: Assembly 1
- Start by soldering a capacitor and one red/black wire to your motor (see photo)
- Attaching the 2 motor mounts to the motors themselves with (2) 2-56 x 1" screws and nuts.
- Place the motor's cross member between the 2 motor mounts and place this assembly on the bottom plate
- Secure this assembly with (2) 2-56 x 3/8" screws and nuts
Step 3: Assembly 2
- Attach the 2 rear wheel supports to the rear cross member (note: this is similar to the motors, but includes a screw coming in from the side --see pictures)
- Place this assembly on the bottom plate
- Attach this assembly to the bottom plate with (6) 2-56 x 3/8 screws through the bottom plate
Step 4: Assembly 3
- Find the top plate and note that the hole for the battery wires must be on the left (I'm pointing to it in the picture)
- Install the (4) 20mm standoffs
- Route the motor wires through the center hole and place the top plate over the bottom assembly
- Wiggle it around a bit and get all the "tabs" to fit in their corresponding "sockets" and also get the motors to sit in their little cut-outs
- Screw the top plate down with (8) 2-56 x 3/8 screws. It is handy to use some needle-nose pliers to get the (4) "center" nuts up-and-in-there.
Step 5:
- Find the electronics plate, your servo
- If you purchased a complete kit with an Arduino Nano and Undershield, install the (3) 10mm stand-offs. These should be installed with nuts on the underside of the plexiglass plate and the end with screws, going up.
- If you are using a different brain (not the Nano) you will need to place your micro controller board on top of the plate and find the mounting holes that line up. If you are using stand-offs or spacers that will need to be attached via the underside of the plate, attach them now.
- Install the servo with the shaft positioned so it is centered and screw it down with (2) 2-56 x 3/8 screws. Route the wire through the center hole
- Prepare your switch plate. Install the 2 switches (if you want to switch the data power and motor power individually) and solder a short piece of wire between them.
- Prepare the battery pack. Find the (2) 2-pin leads and connect the 2 black wires to the black wire coming out of the battery pack --solder it and tape or shrink tube it. The red wire from the battery pack and the (2) red wires from the leads will be left disconnected for now, until we install the battery holder.
- Install the battery pack to the underside of the top deck (not the electronics deck) using the (2) 2-56 x 1/4" flat-head screws (they are the black ones)
- Run the battery pack wires up through the hole in the deck
- Place the switch plate's tabs into the 3 socket holes toward the back of the plate
- Finish up your soldering. The red wire from the battery gets soldered to the first switch and also to the jumper going to the second switch. (This will send power to both switches)
- Solder the last 2 red wires (from the 2-pin leads) to the 2 switches. (This will send power to the micro controller and motors as each switch is clicked)
- Place the electronics plate (running all the wires through the center hole) on the bottom assembly and attach it to the stand-offs
Step 6: Assembly 5
- Unwrap your tracks set being careful not to loose the little washers
- Press the 2 front wheels on to the motor shafts. They should not go on all the way, leave a 1/8" or so. Also, the "teeth" of the wheel should point to the outside
- Grab a rear wheel (with a round center hole) and slide the axle bolt through it. Now add, in this order, a washer, the small circle and then the bigger circle. Now slide the bolt/wheel assembly through the hole in the back of the rear wheel support. Attach it with the nut.
- Repeat all this for the other side.
- You may now (carefully) stretch your tracks on
Step 7: Assembly 6
- Assemble the sonar bracket by attaching the (2) 1/2's with (2) 2-56 x 3/8" screws.
- Bore out 2 holes in the servo horn (that match the holes in the bracket) to accept the 2-56 screws. You can do this with a drill bit, of course, but it is just as easy to do with the spinning the tip of an X-acto knife in the hole.
- Attach the bracket to the servo horn using (2) 2-56 x 1/4" screws
- Attach the Sharp sensor (or SRF-05 or Ping) to the bracket using (2) 4-40 x 3/4" screws, (2) spacers and nuts
- You should wait to attach the sensor bracket to the servo until you get a chance to run some code to center your servo and thus, be able to get it on straight.
Step 8: Assembly 7
- If you ordered the complete kit and are using the Arduino Nano, you will need to go ahead and solder together the Nano Undershield Kit. More information can be found here.
- The instruction manual and assembly instructions can be found here.
- Pay careful attention to the use of the jumper block and power connections.
- Assemble the Undershield and attach it to the (3) 10mm standoffs, routine the motor wires, switch wires and servo wire out from under it.
- Plug in the motors, switches, servo and sharp sensor. For the love of God, you MUST get the polarity and position of these wires correct! Read the instruction manual for more information!
- Plug in the Arduino Nano into the Undershield
Step 9: Assembly 8
- Install the (4) 40mm stand-offs to the electronics plate. --All the holes are close to the edge, it should be easy to get the screws up through the plate
- Attach the accessory plate to the (4) 40mm stand-offs
- The accessory plate is quite useful to allow you to add a breadboard, other sensors, a camera attachment, etc etc.
Note: The picture below shows an alternative sensor
Step 10: Done!
That's it, homie-G.
You are done. Woo Hoo!
Double check all your connections, double check the polarity of all the connections. Install your batteries. If you are going to connect to the end of the Nano board, you will be connecting to the input that goes to the voltage regulator of the Nano itself. Feel free to use alkaline batteries. If you are using rechargables (which put out a lower voltage than alkalines) you may want to use the input on the side of the nano board. This connection goes directly to the Nano and bypasses the volt reg. PLEASE check the instruction manual to learn more about these connections and how the jumper block should be installed.
Now zap some code in! I would start with the basics, testing each "system" individually. Write some simple "read ADC" code to test the sharp sensor, write some code to run the motors and check the direction and run some code to sweep your servo. If all these guys check out, well, then happy coding to you!
