Introduction: Rocket Launcher (Potato Canon)
Hello Guys ,
We are back again with a new project named as "Potato Canon"
First we have made its video on our YT Channel i.e HRzero 8
You can watch that video (But it is in Hindi) or read this instructable!
Don't Forget To like Comment and subscribe our channel
Step 1: Parts
4.5 Feets ( 2 inch Pipe )
1.5 to 2 Feets ( 4 inch Pipe )
4 inch to 2 inch Reducer
4 inch pipe clean out
Gas Lighter
Any Flamable gas
Step 2: Markings
Firstly Mark the area which we want to cut . Mark It with the help of A paper Or any other thing
Tip - Marking should be done in proper manner so that Everything Will work fine
Step 3: Cutting the Area
Then Cut the 2 inch pipe and then the other piece of 4 inch pipe
Tip - Prefer to do it with cutting machine or dremel . Handle it sensitively
Step 4: Washing
Wash Each and every Element So That any particle does not act like a barrier in our project
Then Wipe it with a microfiber cloth Hardly . And check out that Water does not left on the surface
Step 5: Putting Reducer
Make the end of 4 inch pipe rough with help of cutting scale or anything
So that the reducer can make friction
Put the reducer on the end of surface Before Putting Reducer apply some Cement on the rough end
It is because Cement act like a bonding agent in Between them
Step 6: Placing Gas Lighter
Drill a hole For Your Gas Lighter (Drill that much hole so that your lighter can be easily fixed )
Tip - Do it with a Drill Machine which have a scale fixed in it
Then just put a layer of tape around the whole so that the force which lighter put can be easily handled by the pipe
Step 7: Joining Pipes
Join The 2 inch Pipe with Reducer ( Firstly Make the end rough and apply some cement so that it can make a good bond)
Then apply some tape around it
After that put an extra layer of Pipe at Joints and again put a layer of tape on it
After that Close one end of 4 inch pipe with The cap
Step 8: Heating the Cement
Put a lamp or give time to canon for making the bond strong After Some days when the cement become dry
Make the end of 2 inch pipe Sharp that when we put potato it can easily be cut and become easily compressed
Step 9: Lets Rock !
After 2-3 Days it is ready to Rock n Roll
We have made it in just ₹550 (INR)
If you feel that it is informative just like this instructable and comment down below
Don't Forget to like our video Comment on it and subscribe our channel
Tip - My friend Gave me idea to make it bluetooth controlled
I am working on app ( You can also make it automatic by just putting an arduino and a HC 05 Bluetooth module )
Feel free to mail your queries or anything In which You need help from Me
