Introduction: Rod Mount
Mount to hang fishing rod on wall.
Hole for fishing rod handle is 30mm and mounting holes are 1/4" 62.2mm apart.
Scale-able for your rod diameter and you can mount the two separate parts at different heights for the most support for your fishing rod.
Works for any round thing you need to mount from flagpoles to brooms to gaffs.
There are two pieces that you need to print one has the 30mm hole all the way through and the other only partially.The one that has the through hole gets mounted up top so you can lower the rod through into the lower one.
Included is the two .stl models and their Google Sketchup counterparts.
