Introduction: Rotating Jewelry Box
In traditional jewelry boxes, it's common that the necklaces get tangled, which can lead to knots that are difficult to undo. Because of this I wanted to make a jewelry box that could hold necklaces, bracelets, or rings, so I designed a prototype with multiple hooks, as well as the ability to rotate to make it easier to use.
Materials
- Clips
- A piece of cardboard
- PLA
- Glue gun
- Silicone sticks
Step 1: Design the Jeweler
When I had the design in mind of my prototype, I drew it in an application called Onshape, which is used for creating computer-aided designs, and that's where I started creating each part of my jewelry box, I started drawing it in centimeters, but having in mind that it will be printed in 3D, so it could not be really a big or a real size product
Step 2: Lower Base
This piece (the bottom base) of the prototype was created to be able to rotate the rest of the body.
Step 3: The Rest of the Prototype
This piece was designed to be the prototype´s part to rotate and unfold from the lower base
Step 4: Upper Base
The upper base was created to connect with the rest of the protype and paste the hooks
Step 5: Assembly
When each part of the prototype was done, I assembled them, to see how it would see.
Step 6: 3D Printing
Once I had both parts of my prototype in STL format, I transferred them to UltiMaker Cura to print my pieces in 3D, where some supports were added for a better printing. After 2 hours of this process, the pieces were printed, and all the supports were removed, so I could make the modifications planned.
Step 7: Stability
To give a support to the base of the jewelry box and allow it to rotate, the bottom part of the prototype needed stability. With the help of a cereal box, I cut a piece of cardboard and paste the lower base.
Step 8: Hooks
With the help of clips I cut them as a shape of hooks, and with hot glue, I attached them to the edge of the upper base.
