Introduction: Rotating Lamp Cover
I made a interactive rotating fabric lamp cover which you can also move it up and down.
Hardware:
3D printer at least 15cm*15cm*15cm
TPU and PLA
textile that can be bounced with TPU
heat press machine
scissors that can cut fabric
adhension
a round lamp with a hole at center which diamater is smaller than 13cm
Software:
Fusion 360
Ultimaker Cura
Step 1: Print the PLA Parts
download our f3z file and export as stl file , then slice in Ultimaker Cura and print them
Step 2: Print TPU Parts
download our f3d files and export as stl files, then slice in Cura and print 15 parts for each file(30 in total)
Step 3: Cut Fabric
Cut 15 pieces of 3mm*150mm elastic fabric
Step 4: Heat Press Fabric and TPU Parts
The 2mm*3mm adhension is between the TPU and the cloth, and the ends of each cloth are connected with a large TPU part and a small TPU part respectively, with the cloth on the top and the TPU on the bottom, 280 degrees heat press for 10 seconds. Repeat this process for 15 times.
Step 5: Assemble Step 1
Pass the Top part through the hole in the middle of the lamp
Step 6: Assemble Step 2
2.Slide the end of the fabric connected to the larger TPU part into the groove of the bottom part and repeat 15 times
Step 7: Assemble Step 3
3.Pinch the place of the bottom part that is shown in the image 3 and insert the middle column of the bottom part into the column of the Top part.
Step 8: Assemble Step 4
Slide the TPU parts at the other end of the fabric into the grooves of the Top part
