Router Table Cabinet
Intro: Router Table Cabinet
In this project, I'll show you how I built the base cabinet for my router table.
If you want to see how I built the router table top and fence click here.
STEP 1: Gather Tools & Materials
Materials
- (1-1/2 sheets) 3/4″ plywood
- (1 sheet) 1/2″ plywood
- (1 pair) Euro hinges – frameless ½ overlay
- (2 pairs) 20” Drawer slides
- (4) 3” locking caster wheels
- (16) 1” lag screws
- Pocket screws (1-¼”)
- (7) Drawer knobs
- (2) Drawer pulls
- 4″ dust port
- Red spray paint
- Safety paddle switch
Tools
STEP 2: Assemble the Cabinet
I started by cutting down all my plywood to size, then used my pocket hole jig to pre-drill all the pocket holes I would need for assembly.
With all the holes pre-drilled, assembly was easy. I started by attaching the back panel to both sides using some 1-1/4″ pocket screws. Tip: Before this step, it’s a good idea to trace a line 12 inches down from the top on a 3 sides.
Next, I inserted the middle divider that I butted up to the references lines I drew in the step above. I used some spring clamps to help hold it in place while I secured it from underneath with some pocket screws.
I then slipped the bottom panel underneath and screwed down the cabinet on all 3 sides.
P.S. You'll find plywood cutting diagrams on my website - click here.
STEP 3: Make the Lower Drawers
To figure out the size of my drawers, I first measured the width of the opening (33-1/2″) then subtracted 1 inch to account for the thickness of the drawers slides I’m using. Since my drawer slides are 20 inches long, my drawers will be 32-1/2″ wide by 20″ deep. I used 1/2 inch plywood to make the drawer boxes. I made one drawer with 9 inch sides and another with 4-3/4 inch sides.
To assemble the drawers, I first applied some glue to the seams and used brad nails to help hold the box together while I screwed in some pocket screws.
With the slides assembled, I applied glue all along the bottom and dropped in the bottom panel that I secured with brad nails.
STEP 4: Install Drawers Using Slides
This was my first time working with drawer slides but the process is pretty simple. For the bottom one you’ll want to use a small spacer to raise the drawer up a bit, then set the drawer slide an eighth of an inch back. Holding it firmly in place, just pull the slide out and find the screw holes to secure it to the cabinet.
Next you can pull the drawer out just a bit along with the bottom spacer and attach the slides to the drawer, then work your way back to the following screws.
For the upper drawer, I repeated the process using my Kreg drawer slide jig which made the job easy.
STEP 5:
To attach the drawer faces, I started with the bottom so I could use the table to line up the bottom with the cabinet. I clamped the face to the drawer box securely, then slid out the drawer and used a countersink bit to drill some holes in from the back, then secured the face to the drawers with some screws.
I repeated the same process for the upper drawer, but used washers as a spacer between both drawers.
STEP 6: Attach Casters
Before the cabinet gets too heavy, I decided to move it to the floor. I first however flipped it on its back and attached some 3 inch caster wheels using some lag screws.
STEP 7:
My router table top has a port in the fence for dust collection, but I also want to collect the dust that falls below the table, so I’m adding a 4 inch dust port to the back of the cabinet.
After moving the cabinet down to the floor, I traced the out the port (both inside & out) and used my jigsaw to cut out the hole.
I used some Weldbond glue to create a seal and attached it to the cabinet with some screws.
STEP 8: Upper Drawers
For the top part of the cabinet, I wanted to add small drawers, but decided to go with simple wooden slides that I nailed into place with my brad nailer.
I repeated the same pattern on a second panel, then checked to make sure my drawer bottoms would fit before securing the panel to the cabinet with some pocket screws.
I then repeated the same thing on the other side of the cabinet.
STEP 9: Access Door
The top middle section is going to be a door so I can easily access my router from underneath if I have to. I used a hinge jig with a 35mm Forstner bit to countersink the hinges.
I loosely attached the fasteners to the cabinet leaving some wiggle room.
Using washers as spacers on the bottom, I mounted the door, and made the final adjustments using the adjustment screws.
STEP 10: Top Drawer Fronts & Hardware
Moving back to my top drawers, I added these blocks as faux fronts, which are basically just so I’ll have something to attach the drawer fronts to.
Using my trusty washers to get the spacing just right, both on the bottom and on the side, I clamped on the face, drilled some countersunk holes from the back, and secured the face with some screws. After that it was rinse and repeat for all 6 drawers.
To attach the knobs, I used this Kreg drawer pull jig to help place the knobs consistently.
If you’re wondering how my hardware went from nickel to red, I ended up removing them and spray painting them with Regal Red spray paint, just because I liked the look better.
STEP 11: Drawer Trays
I’m not sure what I’ll use all my upper drawers for yet, but I decided to fit one of them with a router bit holder I made out of a 2 by 8 by drilling a bunch of quarter inch holes into it, since my bits all have quarter inch shanks.
For another drawer I decided to make a simple box where I’ll be able to store the main tools I’ll use for the table, like the lift handle and wrenches.
STEP 12: Attach Top to Cabinet
In the final stretch now, it’s time to attach the table top. If you haven’t seen Part 1 where I show how I built this table top, be sure to check that out.
After lining up the top to where I wanted it, I attached it from underneath with pocket screws using the pre-drilled holes I had made.
STEP 13: Mount Safety Switch
A router table really isn’t complete without an external safety switch. After mounting the switch to the door on the side closest to the hinge, I used a Forstner bit to make a hole and feed the wires through.
STEP 14: Go Build Something!
So that wraps up this router cabinet build!
Be sure to check out the video tutorial if you haven't already done so. If you like what you see, subscribe to my YouTube channel to get notified when I post new builds.
______________________________
Here are some more of my latest projects:
8 Comments
gm280 5 years ago
Nice router table. It looks pretty similar to The New Yankee Workshop's version. I actually made mine from Norm Abram's plans. I deviated some to fit my needs but it is close. And it looks pretty close to yours as well. It is one of the best things I've built for the shop. I built mine from MDF and hard woods because it is very heavy and a router table need to be solid. And I also used dual locking casters so it stays put when I lock them. Here is a picture of mine. You can see the similarity.
diymontreal 5 years ago
I've gotten that comment a few times now, had to look him up!
Yours looks great too. I can see the similarities. I've actually added a few holes in the center compartment as well for better air flow.
gm280 5 years ago
Yea, I got those holes for the air flow. Otherwise a vacuum has a hard time pulling the dust out. The switch is merely a typical wall type switch. And that is because the router itself has a variable speed setting and a soft start feature as well. And that wall type switch also turns on a switched outlet on the back for a vacuum use.
Your looks great. I wouldn't change anything with it. You will love using it a guarantee you. In fact I just finished using mine yesterday and it always performs perfectly.
Thumbs Up on your project for sure!
DoreneS3 5 years ago
Thank you so much! :)
twindad3 5 years ago
This was all my own...Sad to say I'm not familiar with him! But someone else made the same comment on my YouTube video. I'm curious, will check him out for sure.
Kink Jarfold 5 years ago
You do such nice work. KJ
