Introduction: Rubber Band Gun
Easy rubber band gun made in twenty minutes with only hand tools and glue. It works well and shoot over 10m depending on the type of rubber band.
Step 1: Step 1: Sketch
Hear i sketched a template to copy and the measurements can be what ever you want but i had mine 21 cm by 9cm. From there you trace the template onto the wood you use i used a bit of old deck.
Step 2: Step 2: Cutting the Wood
During this step wear proper safety gear and use a hand saw to cut out the shape of the gun.
Step 3: Step 3: Sanding
Hear i smoothed out the rough edges with a file then made the smooth with sand paper.
Step 4: Step 4 : Glueing
Hear i glued the handle and peg to the barrel to complete the build.
