Rubber Band Lamp
Intro: Rubber Band Lamp
Make this super cool rubber band lamp with a few pieces of wood and some rubber bands!
STEP 1: Gather Matherials
- (2) 4" Square Wood Plaques. I got a 4 pack from Hobby Lobby for $2.99
- (4) 3/8" x 8" Wooden Dowels- you can get a long dowel and cut it to size
- Drill & Bits: Spur Point (3/8"), Spade Bit (3/4")
- Lamp Cord Set: Snap-In Pigtail Candelabra-Base Socket and Cord Switch
- Candelabra Bulb (preferably a low-heat bulb like an LED- rubber bands can catch fire if there is enough heat)
- Hammer
- Wood Glue
- #64 Rubber bands
STEP 2: Drill
Get your wood plaques. With a pencil, mark out a square whose edges are 3/8" away from the edge of the wood (I tried making the holes closer to the edges and the wood ended up splitting, which made the corners break off). After you have everything marked, use a drill to make holes in the corner of the square that are 3/8" wide and about 1/3" deep; be careful not to drill all the way through.
STEP 3: Drill Some More
Mark the center of the plaque and drill a hole that is 3/4" wide- I used a spade bit to do this (1" wide might work as well, depending on the size of your bulb). When drilling, make sure to have a scrap piece of wood under you plaque for when the bit comes through the bottom. I went 3/4 of the way down and not all the way through because I didn't want a huge hole in the bottom of the lamp.
STEP 4: Lighting
Install the cord by squeezing the metal part in and pushing it down into the hole. It should fit snugly. Excuse my dirty cord- it came from an old lamp.
STEP 5: Clean Up
Clean up pencil marks with an eraser and a wet cloth. I used the eraser first, then the cloth, then the eraser again. This got rid of most of the pencil marks.
STEP 6: Build
Put a dab of glue into each hole and place the dowels into the holes. Give them a hit with a hammer to make sure they are firmly in place. When attaching the top put some glue into the holes, insert the dowels and tap with hammer- to prevent any damage, make sure to put something between the hammer and the wood.
STEP 7: Rubber Bands
Stretch all of the rubber bands before use. When you stretch them, they should turn a lighter shade. If there are dark spots or if the color is splotchy, stretch the dark spots and they should lighten up.
Put the rubber bands on by stretching them around the top of the lamp and pulling them down to the bottom.
STEP 8: Bulb
Move some rubber bands aside so that you can insert the bulb. I put the bulb in before putting the rubber bands on because I didn't want to break the bulb while I was handling the lamp.
STEP 9: Done!
Arrange the rubber bands however you please!
20 Comments
Cyberchipz 8 years ago
Has anyone made one and knows the life of the rubber bands used? I've used rubber bands for many things, and I know they rot. It does seem to take some time, and I know that warmth or heat does cause them to age more quickly; but, never actually noticed how long they last. It seems I just use them, and then one day notice they're rotting.
CaptSnaz 8 years ago
These illustrated look like Postal Rubber Bands, which can be bought cheaply & in quantity. Thus, replace as needed from an inexpensive source.
Anthony. 8 years ago
Your right..but my experiences have been with the freezer...i would put packages of food, with a good strong rubber band and eventually it would break off easily. I like the concept of this lamp, but it looks like temporary.
Yonatan24 8 years ago
Awesome! This is probably the only kind of lamp hat an incandescent bulb looks better
Or not, Can't it make the rubber bands dry and crack from the heat?
zimitt 8 years ago
If you painted this blue, it could be a Tardis lamp.
Very cool. Love the light it casts.
algoritmos 8 years ago
I liked, but it would be better to use an LED bulb to save energy, reduce the temperature and prevent drying of the rubber bands.
Saiyam 9 years ago
Rich1953 8 years ago
A few thoughts i have, i Iove-love your choice of the light bulb.
Rubber bands do break down with heat and ultraviolet light. I'm thinking about using colored string. Easily to wtap and control tge spacing. Making a frame to hold the top of the poles with a removable lid, for easily change of the bulb.
monkeys in a tv 9 years ago
TschNJ 9 years ago
krivas 9 years ago
Thanks!
ldt_tx 9 years ago
krivas 9 years ago
Thanks
goldlego 9 years ago
Wow! That's awesome! So many unique combinations all with just one lamp. Great job and thanks for sharing!
krivas 9 years ago
Thank you!
ClenseYourPallet 9 years ago
krivas 9 years ago
Thank you!
