Introduction: Rubber Bottle Holder
In the ible I will show you how to make a quick water bottle holder. This only takes about 5 minutes to complete and works very well. I did make the design and it can hold about 6-7 lbs which is a lot more than the standard water bottle. So to get started you'll need the following:
-bike tube (you need a 3"x 2 1/4" piece)
-scissors
-pen
-string or shoe lace
-water bottle
Step 1: Getting Started
To start, cut a 21/4in. section of the tube and then cut it in half, depending on the size of the tube you should have at least a 21/4 x 3 in. section. the cut out the design and trace it onto the tube section
Step 2: Cutting It Out
Now cut out the design and then cut out the inner circle, for the two smaller side hole, I used a hole punch which worked very well.
Step 3: Attaching the Cord
Now select your cord that you plan on using and tie each end through the holes. Now its complete! just put the water bottle neck through the big hole and your done!
Step 4: The Finished Product
Here is what it should look like when its done.
ask if you have any questions
Enjoy!
Enjoy!
