Rubik's Cube 3x3 Triangle Switch
Intro: Rubik's Cube 3x3 Triangle Switch
Md= move the middle part down
STEP 1:
The Rubik's cube needs to be solved to do this trick, to see how to solve it check out my other intructable.
STEP 2:
Pick two sides.
STEP 3:
Now turn the cube like this: Md U
STEP 4:
STEP 5:
STEP 6:
When it gets to be like the picture, turn the whole cube(not the sides) down then left. Once you do that you continue those steps do: Md UFOUR times. Then you turn the cube again down then left and do the same steps FOUR times.
STEP 7:
This should be your outcome if it is not try again, but it you did it congratulations. To get back to normal jut do the same steps again
