Running a Dead MP3 Player on AA Batteries
Intro: Running a Dead MP3 Player on AA Batteries
I Find It Offensive That People Will Discard A Piece Of Technology Without Even Trying To Fix It .
So For Your Reading Pleasure Here Is How to Save A Dead Mp3 Player After It No Longer Charges The Battery.
STEP 1: Background and Parts
Hi Guys Nice to see you again.
Here we have a slight disappointment.
A yard Sale find that wont work.
I got this lovely little 1 GB mp3 player for a couple of bucks but it wont hold a charge.
it was a nice one with ebook reader ,
mp3 voice recording,
video player and picture viewer.
its too nice to just toss
when it was plugged into the usb it worked ok so we know the guts are ok.
So wheres the problem? is it the battery or charging circuit?.
To do the full test series that i did you will need.
1. cordless phone battery 3.7v 600 mah {The little battery in the player was 350 mah}
2. vinyl tape
To do the other test {will It run on AA batteries?) and final mod you will need.
1. 3 AA Batteries (Alkaline Or Nimh i tried both)
2. Enclosure (altoids tin or lozenges)
3. A battery holder for 3AA
4. Hot glue gun
5. Vinyl tape
6. A strip of Aluminum
7. Aluminum foil
2. vinyl tape
4. Hot glue gun
5. Vinyl tape
7. Aluminum foil
STEP 2: Will It Work at All
1. The first thing to so is to take the back off the player.
its pretty easy as there are just 3 screws holding the metal back on it .{not all players will be so easy to take apart }.
2. Locate the battery.
3. Snip the wires one at a time so you dont cause a short (CAUTION BATTERY MAY BE CHARGED EVEN THOUGH PLAYER ISNT WORKING).
4. Gently remove the battery.in this case it was held onto the back of the screen by sticky tape .
STEP 3: Testing
this step took a while as the phone battery didnt come charged up.
all you need to do is charge it first
you could put it in a phone then charge it up.
but i didnt have one handy so i wired it up red to red black to black then plugged The player into the usb on my computer.
2 days later the battery had enough juice to start the player but not for long.
it seems likely that the usb hub i have cannot supply enough juice to run this battery up to full.
but at least we now know the player will work from a battery pack.
so if you want to do it this way get a battery that fits your home phone and a plug that fits the connector on the end of the battery leads.
swap out the battery with the phones one and charge up the new one then simply plug it into the connector on your mp3 player .
then just stick the whole thing in a box and youre done.
but can you run it on AA Cells?
STEP 4: More Testing
I was pretty sure starting off this step that a 3 cell battery of AA would supply enough power to run this player.
but would it be too much?
rather than go out and buy a new 3 Cell battery holder and smoke the player out i made a 3 cell taped up pack first.(save the cost of the holder if nothing else)
conversely you could run your cordless phone off one of these too in a pinch.
the picture tell the story here but basically you just take 3 cells alternate the poles and use aluminum strips or foil or even wire to jump the batteries together leaving a neg and a positive pole at opposite corners.
attach leads to the corners run positive to red and negative to black then tie into the player..
be careful here the wires touched each other and the pack got very hot very quick.
well it worked really well the player ran good and nothing got too hot even though the voltage is now 4.5 instead of 3.7.
so now for something a little more permanent.
STEP 5: Now for the Final Configuration.
I Went to buy a 3 cell holder but couldnt get one.
so i bough a 4cell holder and made a dummy battery out of a dowel wrapped with foil.
i then popped the assembly into the sucrets box(it was a nice tight fit) ,
wired it up to the player,
then secured everything in place with hot glue.
so far it has been running for 6 hours and the battery icon is still full.
i will update on how long it lasts before i have to change them out.
the i will go with the nimh cells and see how far they go.
i am considering moving the body of the player into the box and accessing every thong from the inside but i havnt time to fool with it today.
if i do i will add it as an update
STEP 6: UPDATE
UPDATE
here is the player after i moved the player inboard.
it works ok except the back needed to be cut out and the battery pack
offset to clear the back of the player.
had the built battery pack worked better it would have fit without chopping the case.
i am getting about 25 hrs of continual use out of aa alkalines and still havent killed a set of NimH in it.
STEP 7: Yet Another Update
i have just replaced the li ion battery with one out of another broken player.
so the pocketability of this thing just went way up.
the advantages of having replaceable batteries i will miss but i wont miss my friends cringing when i take the player out.
as for the other player i crammed the main circuit board into an sd card case and made a jumpdrive out of it.
later
later
15 Comments
markusnashorn 2 years ago
My mp3 player is very small, is there a chance I could get in contact with you and you could get me some tips? I haven't read everything yet, I am not sure if I could do everything yet, but I am so happy I found someone who not only thought of repairing a device with a broken lithium battery but thought of using AA batteries! Any chance you could do a similar project and tutorial with Nintendo DS Light or GameBoy Advance SP? I just think this should be way bigger and people should be much more aware of the downsides of those lithium batteries, especially if they die and the whole device is useless! I'm never buying another handheld console, music player, kindle, camera (even though they at least have batteries that can be replaced when using them, and can be charged outside the camera, even though there specific batteries for different models), loudspeaker or bike flashlight that doesn't use normal batteries. The ones I have are presents, and the second mp3 player I got from Sony looks like I can't even open it without breaking something. Even though for Sony there is a chance of finding fitting replacements (another down, even if the power is right, the shapes are different), but I was lucky I could crack my old mp3 player open. Getting power from one battery into a device thath doesn't fit, is something I want to learn, jsut as charging those batteries without them being inside the device.
AGAIN thank you for being the first one to think of this, and sharing the belief that you should repair stuff and highlighting the problems caused by the way lithium batteries are used by people right now. I really hope you can tell me if something like this is possible for Nintendos, and if you are interested in dealing with a much smaller mp3player.
Onixgato 7 years ago
Just made something similar to feed my mp3 player with three AA batteries. Thanks for the inspiration.
lennyb 7 years ago
Onixgato 5 years ago
And again, I just resurrected that old player with one of those rectangular external batteries for cellphones. It makes a nice support for the player and since it also has a nice camera I can use it for video recording and taking pictures. I get up to eight hours of playtime. Maybe I should get a new player, but I am flat broke, so I get to have fun recycling things. Again, thanks for the inspiration.
krusher67 12 years ago
Krusher
nathanid95 14 years ago
lennyb 14 years ago
Phil B 14 years ago
lennyb 14 years ago
Phil B 14 years ago
lennyb 14 years ago
spacepirate04 14 years ago
lennyb 14 years ago
ironsmiter 14 years ago
Now I have a new tool, to test the charging circuitry of li-ion devices, if i ever lose my spare batteries. Hook up the phone battery, plug in USB, and watch for the "charging" icon!
As a side note, I'd personally use a mintyboost and replace the battery with a small resistor, till i could scavange a new one.
Is that really 350mAh battery? that suckers gonna run FOREVER on the AA pack!
Nicely done.
lennyb 14 years ago
