S-Video to RCA Connecter
Intro: S-Video to RCA Connecter
How to build a computer to TV converter or s-video to RCA
originally from link
Sorry i decided to make this instuctable after i made the converter
STEP 1: Get Your Parts
An electronics store should carry all of these parts but your store may not.
1.S-Video connector link
2. RCA connector and cable ( I salvaged mine)
3. 470pf ceramic capacitor (I already Had One)
4. Wire
5. Solder
6. Soldering iron
4. Wire
5. Solder
6. Soldering iron
STEP 2: Build
follow the instructions on how to build it
Pin Out
1. Y Ground
2. C Ground
3. Y Data
4. C Data
First connect the Capacitor to pins 3 and 4, then connect 3 and 4 to RCA Data.
Second connect pins 1 and 2 to RCA ground.
third close it up and try it out.
Pin Out
1. Y Ground
2. C Ground
3. Y Data
4. C Data
STEP 3: Try It Out
Plug it into your computer and your TV.
Of course your have to fiddle with settings.
First put your TV into TV\Video Mode.
Then on your computer right click on your desktop and select Properties.
Next select the settings tab and click advanced and turn your display to TV.
You also may need to adjust your resolution settings.
this project will work but wont give you excellent quality text but is good for movies and other media.
42 Comments
bigdaddy1a 10 years ago
hd. septian 12 years ago
rbneville 12 years ago
If you use pins 3 and 1 you will get b&w.
If you use pins 4 and 2 you will get color.
prashantchordia 12 years ago
ScubaSteve 14 years ago
openidordie 12 years ago
Eric
dkumar4 12 years ago
kane89 13 years ago
i have found a few on jameco.com but not sure which to get
firebirdfantom 13 years ago
leifforrest 13 years ago
http://en.m.wikipedia.org/wiki/Mini-DIN_connector
gauzz 13 years ago
I did a cable without the capacitor but it only works for less than a second, then everything goes black.
Do you believe if I use the cap it'll work? Also in what kind of electronics I can find one? I cant find a place that sells a pf anything.
gauzz 13 years ago
Thanks!!!
mountaindave 13 years ago
abadfart 15 years ago
n0ukf 14 years ago
NickEloFun_1 14 years ago
TCPMeta 14 years ago
kidapx 14 years ago
lotusomega 14 years ago
NickEloFun_1 15 years ago
