Introduction: SAMLA Charging Station
Hello guys.
If you're like me i was always looking to find the best solution for a charging station to all the gadgets and tools around the house.
I would like to share with you & the world my version of a simple charging station solution that is low cost, simple to make, No drilling required, easy to put on any surface & most important "instant" to make.
I present to you SAMLA Instant charging station.
Hope you'll like it
Hope you'll like it
Step 1: Requirements
Things you'll need to make your instant charging station:
- SAMLA BOX
- SAMLA INSERT
- Power strip
- Velcro squares
- SAMLA BOX
- SAMLA INSERT
- Power strip
- Velcro squares
Step 2: Inserting Power Strip
Insert power strip through SAMLA INSERT handle.
Step 3: Use Velcro
After inserting the power strip cable through the handle stick 2 Velcro squares on the back of your Power strip.
(Hint: use both the male & female velcro so you'll have double sticky back that will be helpful for the next step)
Step 4: Position the Power Strip
Position and stick your power strip inside the SAMLA box.
Step 5: The End
Insert the SAMLA INSERT inside the box & pull your cable gently.
That's it. Very simple & not a single mess.
Now put your chargers & be creative.
I appreciate your comments.
Thanks.
Thanks.
Step 6: Here Is My SAMLA
To keep it away from children's reach, I've installed it in my kitchen with the help of two BLECKA hooks that were on the wall already.
