SBOT the Recycled Robot
Introduction: SBOT the Recycled Robot
SBOT is a multifunctional robot constructed of recycled material. He moves on command. He additionally displays the time in an attached LED Matrix alarm clock. He can be charged using solar panels, turbines, and other sources of clean energy. SBOT will continue to learn new tricks throughout his doggy life. Below is a more detailed description of what his functions are and how they work. Woof.
Step 1: Materials
Mechanical Hardware:
Two Servos and servo compatible wheels
Two different sized empty food cans
Gears (for the eyes or ears)
An array of old nuts, washers, and bolts, to add onto the eyes
Two back wheels attached by an axle (taken from an old toy rc car)
Two nuts to put the axle through and epoxy to the can
Two green LEDs
An old spring for the tail
Solder iron and solder
Breadboard
Jumper wires
Electrical Hardware:
1 Arduino
1 IR Sensor
1 IR sensor remote control (purchased from Radioshack, but can use any IR remote)
Black and red wire
Toggle switch
Adafruit 4-digit-7-segment LED Display with i2c Backpack
RTC and Lithium module with coin cell battery included
Sparkfun Lithium Ion Battery
SparkFun USB LiPoly Charger - Single Cell
Adafruit mintiboost kit
Piezo Buzzer
Software:
Arduino environment
Servo library
Wire Library
RTC Library
Adafruit LED backpack library
Adafruit GFX library
Make it Robotics Library
Step 2: Mechanical Assembly
Take the two cans. The small one will be the head and the larger, the body. Poke a hole through the bottom, back of the head and top, front of the body. Screw and lock them together with a screw and washer.
Next, use the two nuts to slip an axle through the center and attach the wheels. Glue onto the bottom back of the body. These are the back wheels, or paws.
The front wheels are two servos, glued together and then glued to the front bottom of the can.
For the eyes, two arrangements of sandwiched washers, gears, bolts, etc with the holes lined up in the center should do. Optionally, you may fill in the center holes with a led by slipping it through the hole, soldering wires to the negative and positive and gluing them slightly apart so they don’t short. Glue the eye arrangements down at the back of the top of the head and its magic! SBOT’s got eyes! The ears can be made of any material in a proper size and shape. Glue them to the sides of the eyes. Connect the two led’s powers together and grounds together through jumper wires and insert the power into the digital 10 pin on Arduino and insert the ground into the ground pin on a breadboard connected to the Arduino's ground.
Step 3: Clock Assembly and Programming
Refer to Adafruit’s soldering instructions for the LED Matrix backpacks.
Refer to the above Adafruit fritzing image for connecting the modules to the Arduino. Use a new breadboard. Attach the piezzo buzzer to pin 11 and ground. If necessary, you may use the breadboard. Glue the LED display to the breadboard and the breadboard to the side of the robot. Upload the following code with included alarm setting(plays the imperial march at the time of your choice). Note that the code is a combination of Adafruit’s example titled clock_sevenseg_ds1307 and instructables.com/id/How-to-easily-play-music-with-buzzer-on-arduino-Th/, as well as my own little tweaks and changes.
Step 4: Rechargeable Battery
Assemble the Mintiboost circuit according to Adafruit instructions.
Insert the battery into BAT IN on the charging cell. Now for the System out, solder the assembled Mintiboost's power and ground to the negative and positive outputs.
You now have a fully functioning 5v output battery to wirelessly power your arduino and robot.
Note that you need a barrel jack-wall or barrel-jack USB adapter to charge the lithium ion cell.
Step 5: Servos and Remote Control
Connect the IR Sensor's output to pin 10, the ground to the ground on the breadboard, and the power to 5v. Upload the following code (this is the final accumulative code. It contains every step of this instructable.
Connect the left servo to pin 6, the right to pin 7.
SW1 and SW3=Forward + Reverse
SW2 and SW4= Right and Left
SW7=Stop moving
SW5= Hit the lights
SW6==Sound
SW8=the date on the led matrix
Voila you're done.
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    • For the Home Contest
    2 Comments
    brennerh
    brennerh
    Reply 7 years ago
    thanks you!
