Introduction: ULTRASONIC Patent
Alternative use of 2 hc-sr04
Transmitter the one and receiver the other
Alternative to electromagnetic wireless switch with ULTRASOUND TRIGGER.
Alternative to electromagnetic signal-ULTRASOUND TRIGGER THAT ACTIVATE THE LIGHTS-ALARM OR WHATEVER YOU WANT.
Link to my acount in Github: https://github.com/nektarios25ma/Alternative-to-electromagnetic-signal-ULTRASOUND-TRIGGER-. Trying to activate lights or alarm, wireless with the basic arduino kit, we made a specific ultrasound signal with HC-SR04 that activate another HC-SR04 who act as receiver only .So the first will act as transmitter and the other as receiver. This was used to a school project -AND I WAS THE SUPERVISOR- as a part of smart city miniature THAT PROVIDES "priority" to ambulance of blocked roads with traffic lights. Link to school project : https://github.com/nektarios25ma/GYMNASIO-BRYSWN2 (greece).
1) Arduino uno : https://grobotronics.com/funduino-uno-rev3-arduin...
2) 2 Hc-sr04 : https://grobotronics.com/ultrasonic-sensor-sr04.h...
3) Leds : 2 green ,2 red,1 yellow
https://grobotronics.com/led-diffused-5mm-prasino....
4) 1 Buzzer : https://grobotronics.com/buzzer-5v.html
5)Breadboard : https://grobotronics.com/breadboard-mini-transluc...
6)wires
7) 5 - 220 ohm resistors
Step 1: Presentation to a Class
LESSON PLAN
Student age (13-15)
Stem class
Previous knowledge (basic physics -waves, electicity- and basic experience with arduino projects)
A.BE AN INVENTER (THE ART OF AN INVENTOR)
Talk about characteristics of an inventor (20 minutes)
Link: https://www.invention-info.com/characteristics-of-the-best-inventors
B.UNDERSTANTING SOUND AND ULTRASOUND- USE THE PRESENTATION (POWER POINT)
C. HOW TO MAKE A “PATENT”-ULTRASONIC REMOTE CONTROL - BY A MODIFIED ELECTRONIC DEVICE
1) UNDERSTANTING THE HC-SR04-MAKING THE BASIC DISTUNCE DETECTION CIRCUIT (1-2 HOURS)
TUTORIAL: https://create.arduino.cc/projecthub/Isaac100/getting-started-with-the-hc-sr04-ultrasonic-sensor-036380 OR https://www.instructables.com/id/Distance-Detector-1/
3) UNDERSTANTING OUR NEEDS-ACTIONS-see this instructable.
First we need a transmitter that produces a signal constantly-see this instructable (20 minutes)
Second we need a receiver. Talk about the modification of hc sr04, covering the receiver module in order to receive only and not transmit, and construction-code etc -see this instructable (1 hour)
Possibilities i.e. –next project:The application of this “patent” by the student (13-15 years old,Gymnasio Vryswn): Smart city with clever traffic lights and clever gates that give priority to ambulance and more like city alerts of high or too low temp.
Step 2: Transmitter
The transmitter need only to transmit , so we dont need the echo (receiver), thus its optional to cover it but i recomend to let it free to check the functionality of HSR04.
First the code of transmitter:
#define TRIGGERPIN 8
#define ECHOPIN 9
void setup()
pinMode(TRIGGERPIN,OUTPUT);
pinMode(ECHOPIN,INPUT);
void loop()
digitalWrite(TRIGGERPIN,LOW);
delayMicroseconds(1);
digitalWrite(TRIGGERPIN,HIGH);
delayMicroseconds(10);
Step 3: RECEIVER
We must cover (with cotton and tape) the trigger becouse we want only to receive . If by mistake dont cover it you will have signal from trigger so the wireless switch will faile.
Then the code of receiver:
#define echo 12
#define trigger 13
//leds and buzzers that will activate after the //signal
int ledRed = 2;
int ledOrange = 10;
int ledGreen = 9;
const int buzzer = 7;
long RECEIVER()
// THE TRIGGER SEND A SIGNAL TO ACTUALLY TURN ON THE leds and buzzer via RECEIVER
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH); //trick to enable the receiver
long microseconds=pulseIn(echo,HIGH,100000);
return microseconds / 10;
void setup()
pinMode(echo,INPUT); \
pinMode(trigger,OUTPUT);
pinMode(ledRed, OUTPUT);
pinMode(ledOrange, OUTPUT);
pinMode(ledGreen, OUTPUT);
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
void loop(){
delay(50);
Serial.println(RECEIVER()); //TEST ....IF IS WORKING-SEE THE SERIAL IF THE SENDER-TRANSMITTER //WORKS(OF COURSE ACTIVATE THE TRANSMITTER)
// IF THIS PARTICULAR ULTRASOUND DETECT WHILE TURN ON THE LEDS AND BUZZER OR WHATEVER //YOU WANT
if ( RECEIVER()>= 5 && RECEIVER()<= 29930)
digitalWrite(ledOrange, HIGH);
digitalWrite(ledGreen, HIGH);
digitalWrite(ledRed, HIGH);
tone(buzzer,1000);
delay(400);
else
digitalWrite(ledRed, LOW);
digitalWrite(ledOrange, LOW);
digitalWrite(ledGreen, LOW);
noTone(buzzer);
} //WITH NO SIGNAL THE RECEIVER WRITES ZERO
if ( RECEIVER()<= 5 )
noTone(buzzer);
Step 4: One Possible Aplication That Took Place to a Greek School
Possibilities
link to github : https://github.com/nektarios25ma/GYMNASIO-BRYSWN2
Sensors Contest
3 years ago
A.FIRST follow the doc instuctions.
B.SECOND show the power point.
C.POSSIBILITIES (https://github.com/nektarios25ma/GYMNASIO-BRYSWN2)
PRESENTATION AND APPLY OF THIS "PATENT" :by the
https://www.youtube.com/watch?v=jfiOYmjc7f0https://www.youtube.com/watch?v=UQ0LskqQZeMhttps://www.youtube.com/watch?v=sbNdtB8n2A0&t=1shttps://www.youtube.com/watch?v=ya6-lv3dAWA&t=13s
