Introduction: POS SYSTEM FOR SHOPS, GROCERIES AND SERVICE CENTERS FROM EXCEL With Using Barcodes
I’m intractable with this blog to world how to create a simple POS (point of sales) system for small shops groceries and service centers.
With this method you can manage following facilities without special software or expensive equipment.
v Issue a sales bill using barcode
v Manage purchases
v Control inventory
v Day end and month end stock balance
v Daily sales
v Daily purchases
supporting file can download here
Step 1: Create Workbook
You need some basic knowledge about excel macro to do this simply,
First open an excel workbook with 6 worksheets as followings.,:
1. Bills
2. Pur
3. Purchase
4. Sales
5. Stock balance
6. Setup
Step 2: Create a Setup Page
Next:
Create a setup page with this headings and setup your stock items.
Category : item category
Code : Create specific code for your each items. This must be unique ID no for each items and use this to create the barcodes. Exp:
According to this, take all the inventory items & create a code and update sheet with opening stock, pur.price and Seles price. You have to give the correct purchase price and sales prices because when you issue a bill, price will pick from this sheet. Opening balance will link with stock balance sheet.
Bar code create: you can create bar code with your item code, using online barcode creator or you can download barcode software to do it.
Step 3: Create Stock Balance Sheet:
Copy this formula to each row and copy paste to down:
Code: =IF(setup!$B$3:$B$323<>"",setup!$B$3:$B$323,"")
Description: =IF(setup!$C$3:$C$323<>"",setup!$C$3:$C$323,"")
Opening Balance: =SUM(IF(B3=setup!$B$3:$B$1021,setup!$D$3:$D$1021))
Purchase: =SUM(IF(B3=purchase!$B$2:$B$2005,purchase!$D$2:$D$2005))
Sales: =SUM(IF(B3=sales!$H$2:$H$2551,sales!$J$2:$J$2551))
Stock: =+D3+E3-F3
Step 4: Create a Bill Sheet:
Create sheet according to this format and give below formula to each row and create macro with below codes.
Line: =IF(C5="","",B4+1)
Code: Create a list box link with setup page item code and name. when you connect a bar code reader with bar code sticker details will auto pick.
Description: =I4
Qty : this column you have to enter manually according to customer purchase qty.
Price: =IF(E4="","",VLOOKUP(C4,al,5,0)*E4)
** macro for Save bill
Create a button called Save bill and copy this code:
You can download this supporting file above..
Sub Dayendsales()
' Dayendsales Macro
Sheets("Tsales").Select
Columns("G:G").Select
Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
Range("E2:E255").Select
Selection.copy
Range("G2").Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Sheets("sales").Select
Range("B3:D1572").Select
Application.CutCopyMode = False
Selection.ClearContents
Range("D3").Select
End Sub
Sub DayendPurchases()
' ' DayendPurchases Macro
' Sheets("Tpurchase").Select
Columns("F:F").Select
Range("D2:D643").Select
Selection.copy
Range("F2").Select
Sheets("purchase").Select
Range("C3:D625").Select
Range("E3").Select
End Sub
Sub SaveBill()
' SaveBill Macro
Application.Run "'shop sales control.xls'!copy"
Application.Run "'shop sales control.xls'!SaleReplace"
End Sub
Sub DayEnd()
' DayEnd Macro
End Sub
Step 5: Create Pur Sheet:
create worksheet according to this format.
Step 6: Now Create the Purchase and Sales Data Save Page With This Format:
Step 7: Macro Code You Can Copy Form My File.
Macro code you can copy and paste form above file.
After all the formula and code create you can run the system. When you save the bill, the details will save to sale database and it will update the inventory.
End of the month save the file as new name and delete old data of sale and purchase database worksheet. Before delete, copy the closing stock balances to setup page opening balances column.
I have created some useful office database software to give to world here
Thanks
