Introduction: SIMPLE TISSUE FLOWER
Well school activities and project need decorations and their are many students out there like me who don't like to make complex drawings,origami flower,coloring,etc.So this is the best solution. :)
Step 1: MATERIALS
These are some materials that can be found easily in your houses:
- A scissor.
- Some tissue papers (around 3-4).
- And a thread.
Step 2: SETTING UP THE TISSUES
So take two tissues and put them on one another.If you want you can even use three,but using three tissue will make more petals in the flower and I suggest if you are make something like this for the first time then you should go with the basic.Once it's done cut the double layer tissue paper into half.After this we will have two rectangle pieces of tissue.
Step 3: FOLDING THE TISSUE
Now put the rectangle sheet of tissue paper over one another as shown.Once done fold the sheet,for folding it we should do one fold in the front and the other at the back,it is similar fold we do when we make paper fans.
Step 4: THREADING PART
Once it is completely done take a thread and wrap it around the center till it is tight enough.
Step 5: GIVING IT THE FLOWER SHAPE
Now hold bot side of the tissue and stretch it as show in the image.Once done take the scissor and cut triangles around the corners.(you can even cut hearts and a lot of other shapes too).
Step 6: MAKING THE PETALS
Now this is the tough part.Pick one sheet of tissue of one side and pull it to the center,similarly do with the other side.Keep repeating this the all the tissue layer of both sides are pulled to the center.
Step 7: WE ARE DONE
Now when you had pulled all the tissue layer the flower will look similar like the one showed in the image.I is not necessary that it will be completely same as not all tissues have same type of quality.You can even use colored tissues or add some color to white tissues.Thanks for reading :)
