Introduction: SK112: Smoke Bomb
About: hey Im really 10 I make rockets that go over 1000 feet, pull ring smoke bombs,bombs ect Im postig alot of stuff you will love it all! I love famliy guy stewie well take over the world one day!!
Here it is, I made this for Instructables, and Instructables only.
Hope you have a good time making it. It's fun to spray paint these so they look like a real SK112!
NOTE: This is NOT my idea, but I did modifie it.
WARING: I AM NOT RESPONSIBLE FOR YOUR ACTIONS
Step 1: Materials
Materials for the ignightor:
Stick Matches - 3 Dollars
Paper Matches (1-5) - FREE
5 Inches of Wire - FREE
Straw - FREE
Bamboo Skewer - FREE ( 3 Dollars a pack )
Sciccers - FREE ( 1 Dollar )
Eletricle tape - 50 Cents
Square of Toilet Paper - FREE
Added up: 7 Dollars for ignightor
Step 2: Start
Cut about 3 inches of straw. Wrap tissue around the end of the straw and tape it, make sure its PAPER THEN.
Step 3: Other Side
Put this side that has tissue on it face down ( on the ground ) cut match heads and stuff them in the straw, pack them with a skewer.
Step 4: Ignightor Finished
Rip a pack of matches off the striker. Remove the tiny staple and get one side of the match book. Wrap it around the halfway finished ignightor and tape it. Stretch the tape.
Step 5: Done!
Make the pull-ring and your done with the ignightor!
Cut out two match ignightors. Bend a peice of wire to a ring. Tape the strikers red side down. Make sure they are firmly in place.
Step 6: Smoke Bomb
To make the smoke bomb you need:
Pan- - -$5
Stove- - -FREE
Potassium nitrate/stump remover- - -$5 ( Or More )
Powdered sugar/sorbatal- - - Sugar $3 sorbatal $50
PVC/tube- - -$1-$5
Container- - -$1
Optional:
Fire extinguisher- - -$15
Step 7: Fuel
Make the fuel by getting a 60% KNO3 and 40% Sorbatal.
So, you could double the ratio. For instance
Ratios:
60% 40%
120% 80%
200% 120%
260% 140%
You must Weigh the ratio in GRAMS.
Step 8: Melt the Fuel
Melt the fuel. Make sure not to burn down your house.
Melt fuel at a LOW temp.
Warning:
If you are using sugar instead of sorbatal,
your fuel will look like creamy peanut butter when
done. This mix drys VERY fast. If using sorbatal
have no worries
Step 9: DONE
Put fuel in tube insert fuel into the tube and
insert the ignitor into the tube. Your done!!
