Introduction: SMPS Design With IC TL494 in Push Pull Configuration Primary 12V DC @ 30W Secondary 220 V AC @ 65khz
About: Iam instrumentation and controls professional working in Emirates global aluminium (EGA) located at Dubai. I'm circuit designer and software developer by passion. Whatsapp (+91)9163954390
In this instructable I'm demonstrating a basic switching power supply design using push pull configuration.
The switching power supply is designed to deliver a power of 30W. Input supply voltage is 12V DC and Output voltage is 220 V AC @ 60Khz.
BILL OF MATERIALS
NOTE : All resistors are 1/4 W
C1 22PF
Q1 25N120
Q2 25N120
R1 100K
R2 100K
R3 100K
R4 100K
R5 10K
R6 10K
R7 330E 1W
R8 330E 1W
R9 100E
R10 100E
R11 30W LAMP
T1 TRANSFORMER (REFER DESIGN)
U1 TL494
Step 1: Transformer Design
Transformer Primary = 12 V @ 60 W
Transformer Secondary = 230 V
Primary no. of turns = (Primary volts X 10^10)/(4 x frequency (Hz) X Core area (sq. mm) X flux density (Gauss) )
Primary no. of turns = (12 X 10^10) / (4 X 65000 X 69 X 1500 ) = 4.45 or 5 turns
Secondary voltage = 230 X 1.414 = 325.22 V
No. of turns in secondary = (Secondary Voltage / Primary voltage) / Primary no. of turns
= (325.22 / 12) X 4.45 = 120.6 turns
Wire used = 38 SWG for both primary and secondary windings.
38 SWG wire current capacity = 0.350 A
30 W @ 12 V ==> 30 /12 = 2.5 A
No. of conductors in primary = 2.5 / 0.350 = 7.14 , say 8 conductors.
Secondary can have 1 conductor to serve this power.
Transformer design summary
Core area = 69 sq. mm
Operating frequency = 65 khz
No. of turns in primary = 5 ( 5 + 5 as it is bifilar winding, center tap required for push pull configuration. )
Secondary turns = 120 or 121
38 SWG copper wire
Primary has 8 conductors with 5 turns two windings in bifilar winding.
Secondary has 1 conductor 120 turns.
Step 2: Construction
Make the circuit as shown in circuit diagram.
Make the transformer as per design.
Step 3: Test Result
Supply voltage = 12.22 V
Current drawn from power supply = 2.45 A
Output voltage to load lamp = 225 V AC @ 65khz.
