Introduction: SOUND DETECTOR WITH SCR
About: designer of circuits and professional electronic projects www.pcbway.com
Today we will learn a very interesting project that will serve as a base circuit for more innovative projects. It is the sound detector through an SCR.
Step 1: SCHEMATIC DIAGRAM
Like all my projects, I share the schematic diagram so that you can do it yourself. The schematic diagram was designed in EASYEDA, a very professional and free electronic circuit design software, we can observe the electronic components that we use for this project and their respective values.
Step 2: FUNCTIONING
The sound sensor circuit, as its name says, is a circuit that turns on when a sound wave is perceived, to assemble the circuit it is necessary to have a breadboard, who is in charge of joining the circuit, it should be noted, in case of not having the breadboard, you can connect the components by means of soldering, in turn, you must have a silicon controlled rectifier, better known as an SCR C106, an electre microphone who receives the waves.
 You must have two resistors, one of them must be 10K and the other 1K, likewise, it is necessary to have a push button and a 100K potentiometer, which is responsible for measuring the differences in electrical potential and last but not less important, we must have a 5 to 12 volt battery and the circuit diagram.
How to connect or connect the sound sensor circuit
Firstly, the SCR C106 is inserted in the center of the breadboard, then the potentiometer is placed, in the same way the push button is placed at one point, followed by the 1K resistor joining one of the resistor legs to the Right leg of SCR C106, the other leg of the 1K resistor is attached to one of the legs of the 10K resistor, similarly, the leftover leg of the 10K resistor is attached to the center leg of the potentiometer.
Then we proceed to install the electre microphone which, the positive part is assembled with the two legs of the resistors and the negative part of this is connected to the negative part of the breadboard, then a cable is connected from the left leg of the SCR to the negative part of the breadboard and we connect any of the legs of the potentiometer to the positive side of the breadboard, a cable is connected from the left leg of the SCR to the push button and the other leg of the push button to the central part of the SCR.
Step 3: ELECTRONIC COMPONENTS
  • 1 SCR C106DG
  • 1 PUSH BUTTON 2 PINS
  • 1 RESISTOR 1/4W 10K
  • 2 RESISTORS 1/4W 1K
  • 1 DIODE LED 5MM BLUE
  • 1 POTENCIOMETER 100K
  • 1 JACK DC
  • 1 ELECTRIC MICROPHONE
  • 1 PCB
Step 4: FEATURE
  • VIN 5VDC - 12VDC
  • I MAX 50mA
  • SOUND SENSITIVITY CALIBRATION
  • PULSE OFF PUSHBUTTON
Step 5: EASYEDA
This project was made in the Easyeda software as we can see the tracks and the 3D image of the project working perfectly are no difficulty
Step 6: PCBWay
PCBWAY has 10 years in the electronics industry manufacturing professional PCBs, assembling PCBs managing to satisfy the demands of all parts of the world, in addition to meeting the highest quality and delivery time standards. PCBWAY allows the manufacture of your PCBs from 5 units.
This project was carried out thanks to PCBWAY, a company dedicated to the manufacture of prototypes and professional PCBs, in addition to offering you a ready assembly service with all the components in your PCBS, complying with the established quality and delivery time standards.
We thank PCBWAY, a leading company for manufacturing and assembling professional PCBs with the highest quality, PCBWAY has fair reasonable prices, punctual shipping time and 24-hour customer service, it also offers you the option of quoting all its services in his web page. Do not think twice and start manufacturing your professional PCBs from 5 units safely.
10pcbs at $5 order them here www.pcbway.com
We thank PCBWAY for the professional pcb they provide us for this project.
GERBER PCB:
https://mega.nz/file/7BQVAaBR#opfKfT3dxMTv2TkmC93cUoBHAF00nRzO8zNmFJo_Hqs
