Introduction: SPI to 4 X UART Bridge (MULTIUART)
If your a fan of electronics then you like me will often find it annoying on the lack of hardware serial ports on modern devices. Many modules like the Wifi ESP8266 and the Bluetooth HC-06 are available for peanuts but they each require a UART based serial peripheral on your controller to work effectively. In fact a huge range of external electronics can be added to your system via a serial UART connection: GPS, GSM (mobile phone), RFID, RS232, LIN, Ethernet, Zigbee, Modbus, DMX, 4D systems graphical LCDs to name a few more.
Most modern microcontrollers and devices like the Raspberry Pi have at least one serial UART peripheral so you can do a lot with these devices. However now and then you need to combine several communications style modules together into a single design. A recent project I undertook was a mobile alarm system which used Bluetooth proximity to arm / disarm the system, GPS to track the location, Accelerometer to track movement and GSM based SMS messages to inform the owner where their item is.
The Arduino Mega 2560 offers two serial UART peripherals but what if that is not enough or you need something more affordable for mass production. To move to a different chip may mean rewriting your entire code so is there an easier way?
These modern microcontrollers commonly also feature a peripheral named SPI which is typically a lot faster then a UART based serial peripheral and can be used to talk to multiple devices by use of individual chip select signals from the controller. If the controller does not have an SPI peripheral then it can simply be driven using a bit banged software approach using standard I/O pins with no major downfalls. By using the SPI interface and my design you can communicate with up to four serial UART peripherals simultaneously.
Here is a guide to recreate and build my SPI to 4 x UART bridge for use in your own projects. If you don't want to make your own then I also have a limited number of assembled boards available.
Step 1: The Schematic
The circuit for the board is pretty basic as we are simply using a larger 16-bit PIC micro controller to do most of the work for us.
U1 is the PIC24FJ64GA306 micro controller, I chose this chip because it has four UART peripherals and was the cheapest I could find by shopping around on Farnell and microchipdirect. The chip also features several 5V tolerant I/O pins meaning that even though the device will need to be powered at 3.3V it will work as is with 5V systems.
C1 is a 10uF ceramic capacitor and is required by the micro controller to maintain the internal processor voltage levels. This capacitor need to be placed close to the VCAP pin.
C2, C3, C4 and C5 are 100nF ceramic capacitors to provide some voltage smoothing and noise rejection to allow the micro controller to run reliably. These capacitor need to be placed close to the VSS and VDD pins of the micro controller.
R1 provides the MCLR reset signal allowing the micro controller to run. R2 pulls the chip select signal high by default so the SPI interface is automatically disabled until driven low by the host. R3 is a current limiting diode to drive the communications indicator LED.
J1 is the interface to the host controller. It provides connections such as power (3.3V) and ground as well as the four standard SPI pins (MOSI, MISO, SCK and CS). J2 is the interface to the four serial UART peripherals. J3 is the in circuit serial programming (ICSP) header designed to work with the PICkit 3 programming tool.
Note that if your designing your own board then you might want to include other features to be accessed via the SPI interface.
Step 2: The Bill of Materials
Here is a list of the materials I used in the project.
- 1 x PIC24FJ64GA306
- 2 x 8 way SIL headers 2.54mm pitch
- 2 x 10K Resistor
- 1 x 330R Resistor
- 1 x 10uF Ceramic Cap
- 4 x 100nF Ceramic Cap
- 1 x LED
- 1 x PCB
Also required for the build
- 1 x PICkit 3 programmer
- 1 x 6 way SIL header 2.54mm pitch
- Host controller with SPI interface for testing (I used an ECIO28P from MatrixTSL, an Arduino would also be fine)
Step 3: The PCB
The PCB was created using Proteus and standard 0805 sized surface mount components. Eagle would work just as well if you are familiar with that.
The PCB design was exported as a series of Gerber files and manufactured using Eurocircuits. The Gerber files are attached in the zip file.
The trick with Eurocircuits is to order in bulk to bring down the price per board. So make sure your circuitry is correct before submitting your design. Of course any other PCB manufacturer should also be able to work with the Gerber files.
I ordered my PCBs with a top layer surface mount mask to make the manufacturing process easier. I created a jig for the PCBs to sit in by using my trusty CNC machine to create a pocket in a piece of MDF. The pocket needs a small cut out to ensure you can get it out of the hole easily. I placed a PCB into the pocket and used this to line up the solder paste mask. Once the mask is in place use tape to secure one side of the mask to the MDF. This creates a hinge so you can easily lift up the mask to add or remove the PCBs.
To create the code to drive the CNC I used SketchUp to draw a square the size of my PCB. I then added a small slot to make removing the PCB from the pocket easier. The file was then saved and exported as a .dxf CAD file. I then used the LazyCAM software to convert the .dxf file into G-code which will drive my CNC machine.
Step 4: The Software
The software was created using MPLAB X and the XC8 compiler. Flowcode does not natively support SPI slave just yet so I had to go back to basics with my C compiler.
Flowcode 6 does provide some nice features out of the box such as multiple UART support and circular buffers so this really helped to speed up the development in terms of generating C code i could copy and paste into my program.
I go through the process of obtaining a completely unlocked 30 day version of Flowcode for all chip types in my Two wheel robot Instructable.
To develop the software I created a simple protocol for the SPI connection to allow me to access each of the UART channels functionality. Each value is sent via the SPI as a byte with the CS signal pulled low. When the command is complete the CS signal is pulled high.
The command code and UART channel are packed together into a single byte to increase efficiency. The command code resides in the top 4 bits and the channel resides in the bottom 2 bits.
Here are the bits in the byte and their representation.
cccc00uu
where cccc is the command code and uu is the UART channel.
Command Code - Parameters - Returns - Description
0x10 - N/A - NumBytes (0-255) - Reads the number of bytes in the channel receive buffer.
0x30 - N/A - NumBytes (0-255) - Reads the number of bytes in the channel transmit buffer.
0x20 - NumBytes (0-255) - DataByte (0-255) - Reads data byte(s) from the channel receive buffer.
0x40 - NumBytes (0-255), DataByte (0-255) - N/A - Puts a data byte into the channel transmit buffer.
0x80 - Baud (0-7) - N/A - Sets the channel baud rate
Here are the options for the baud rate parameter.
0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
So to read the number of bytes in UART channel 2 receive buffer we send the following command code and then perform a read.
CS Low
SPISend ( 0x12 )
NumBytes = SPIReceive ( 0xFF )
CS High
To read 5 bytes from UART channel 2 receive buffer we send the following command code, the number of bytes and then perform enough reads to pull out all the data we want.
CS Low
SPISend ( 0x22 )
SPISend ( 0x05 )
Byte[0] = SPIReceive ( 0xFF )
Byte[1] = SPIReceive ( 0xFF )
Byte[2] = SPIReceive ( 0xFF )
Byte[3] = SPIReceive ( 0xFF )
Byte[4] = SPIReceive ( 0xFF )
CS High
To write 5 bytes to UART channel 2 transmit buffer we send the following command code, the number of bytes and then perform enough writes to send out all the data we want.
CS Low
SPISend ( 0x42 )
SPISend ( 0x05 )
SPISend ( Byte[0] )
SPISend ( Byte[1] )
SPISend ( Byte[2] )
SPISend ( Byte[3] )
SPISend ( Byte[4] )
CS High
Each UART peripheral has a software 512 byte circular buffer allowing a large amount of data to be sent and received which should hopefully mean that you never loose a byte.
The LED glows dimly when the board is powered, glows at half power when transmitting or receiving via a UART and glows at full power when communicating via SPI. I thought about having a LED for each UART channel but decided against it in the end, just more components to place by hand.
Step 5: Programming
Programming was done by inserting a 6 way SIL header into the PICkit 3 and then placing this header into the 6 way socket on the PCB. The arrow on the PICkit should go to pin 1 of the ICSP header which is the side marked J3 on my PCB design.
The board can be powered externally or via the PICkit 3. Note the boards needs some method of powering before the PICkit will see the device.
Step 6: Testing
To test the board I used the 5V PIC based ECIO28. I created a simple test jig using veroboard with sockets for both the ECIO and the MULTIUART bridge. The ECIO28 is a 5V device so I used a 3.3V low dropout (LDO) voltage regulator to provide the voltage to power the MULTIUART.
Each of the UART channels has their TX to RX pins shorted together so that anything sent is automatically echoed back. This allows us to automatically test the send and receive functionality of each of the UARTs to ensure everything is working as it should.
The ECIO features USB communications so I can use the Flowcode 6 simulation to communicate with the device and see how the testing is going. Arduino's also have a USB interface so they could also do this type of automated testing using the Flowcode software. Alternatively you could use an LCD or other display to show if the test has passed or failed without the need of a computer.
The nice thing about using the Flowcode software is once you past the testing stage you then have effectively an interface to your four serial devices via USB to SPI to UART and back again. You could even use multiple MULTIUART boards to add in as many serial devices as you need. The same thing could be done using Python if you wanted to do the testing or interface using a Raspberry Pi as the controller.
As a fall back I also have access to a USBee SX which is a very nice piece of hardware for diagnosing problems with serial interfaces. It can decode serial, SPI, I2C as well as others and has helped me out time and time again to resolve problems with digital communications. Shown in the images is my initial debugging rig and screenshots of the software decoding the communications busses. You can really see the difference between the speed of the SPI and the speed of the serial data at 9600 baud.
RealTerm is another handy tool. In the image I show the data coming in via the ECIO28P USB connection. The Flowcode test project file and hex are also included. To convert this for use with an Arduino simply swap the USB component to a RS232 component and change the target in the project options.
11 Comments
2 years ago
Hello, I would like to buy this. . where can I buy this one?
I didnt see this on ebay
Thank you
Reply 2 years ago
Thanks for your interest. You can find the boards here. https://www.ebay.co.uk/itm/SPI-to-4-x-UART-Bridge-MULTIUART-SPI2UART-version2-/283463387641
2 years ago
Hello
Thank you for introducing your awesome device!
I already reproduced your device and it is working fine.
I have one question: what is the license of this source code?
I want to modify some code to adapt to our project(for our research, not business).
Can I modify them?
Of course, I will keep your name in the source code.
Question 3 years ago on Step 6
Hello
I have bought two cards and after one afternoon of work... i dont succeed in communicating with a PI 3.
I use bcm2835 library and on the miso line i see either the data i send on the mosi with one clock delay or "zero".
Do you have a code example which runs on PI ?
There must be something wrong with my code. I have read your firmware and i dont see a case where i could get those answers.
Thank you for your answer.
Francis
5 years ago
@assainsareus Your board hits the spot for a MIDI project I have in mind. MIDI uses 31,250 baud, I can see how to tweak the software but I am a newbie to this type of hardware. If I buy a couple of your board from e-bay, is it easy enough to flash over the firmware with my mods?
Reply 5 years ago
Hello, thanks for the interest, you will need a PICkit 3 programmer to reprogram the device. Its otherwise pretty straightforward using the MPLABX IPE software to program the firmware.
Reply 5 years ago
Thanks for the prompt response, I thought that would be the case but I always like to check with the experts before I go blundering in :)
6 years ago
Awesome board!
Would you happen to have a MULTIUART for sale by any chance?
Does it require some sort of special driver to be able to communicate with a pi?
Reply 5 years ago
Communicating from the Pi is possible using the SPI channel. If you need the UARTs to appear as COM ports on the Pi then this is also possible but you would have to create a driver to emulate the COM ports and convert the access to SPI commands. I've started to look into this and it seems possible but not got time to investigate fully at the moment.
6 years ago
i need this quad uart device
are you selling them? if so contact me yodabox64@ hotmail dot com
thanks
Reply 5 years ago
Sorry for the delay, now on sale here:
http://www.ebay.co.uk/itm/-/282133308451?
