Introduction: SPLITING a NETGEAR RANGE EXTENDER
GOT A NET ADAPTOR WITH OUT AN ANTENNA?
HAVE A NETGEAR RANGE EXTENDER?
CUT ONE ANTENNA OUT TO USE ON OTHER COMPUTER
Step 1: TOOLS YOU WILL NEED
1 STRAIT POKER
2 EXTO KNIF
3 SCISSOR
Step 2: OPEN THE OUTER CASE
WITH THE PRY TOOL INSERT AROUND SEAM
POP THE CLIPS AND YOUR IN
Step 3: PULL THE BOARD OUT AND CUT THE PLASTIC OFF THE WIRES
PULL THE BOARD OUT IT IS ON FOUR PEGS
NOW WITH YOUR EXATO KNIFE CARFULLY CUT THE PLASTIC STOPPER OF THE THREE WIRES WTH OUT CUTTING THE WIRES.
Step 4: CUT OUT ONE ANTENNA
WITH THE SCICCORS CARFULLY CUT AROUND THE METAL OF THE ANTENNA
Step 5: PULL WIRE APART
GRAB THE WIRE U WANT TO USE PULL IT APART
THEN PULL THE THREW THE HOLE OF THE PLASTIC CASE
Step 6: PUT BACK THE BOARD
PUT THE BOARD BACK IN A SNAP THE CASE TOGEATHER
Step 7: HOOK UP TO YOUR NET ADAPTOR
SCEW TO NET ADAPTOR
YES FULL SIGNAL NOW ON BOTH MY COMPUTERS
THANK YOU..... NEW STORE OPENED FOR QUILITY USED GOODS CHECK ME OUT WWW.LANDFILLSAVERS.COM HOPE TO SEE U THERE
