Introduction: SPRING RING
Very easy SPRING RING which you can make it at home only from
1. 2 Copper thin wire of about 20 inch.
2.A pen refill or some wire like thing to wrap the copper wire.
3. Glue.
That's all
Let's start.......................................................................
(sorry for my English
Its very bad)
Step 1: WRAPPING THE WIRE
Take the copper wire and then just wrap it around the wire like thing or refill till you will get the shape of a spring. Then wrap the other wire also. Take out both spring.
Make sure that you should not bend it.
Step 2: OVERLAP
Take the end of the two spring and overlap each other and apply some glue (hot glue if you have).
Do the same thing with other end also after the glue is dried.
Your homemade spring ring is ready.
AT LAST DON'T FORGET TO VOTE ME....
